Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
changing timing belt
Old Nov 5, 2007 | 03:37 PM
Noe18's Avatar
hey guys how hard is to to change a timing belt, can it be a DIY job
Old Nov 5, 2007 | 07:55 PM
SLVROZ_03's Avatar
Took me 11 hours straight! But the timing was the hardest to get right, besides having no air tools. I had to take out the starter carefully "jam" a pry bar in the flywheel in order the loosen the pulley bolt. After that, it was cake!
Old Nov 5, 2007 | 08:09 PM
JohnnyBoy427's Avatar
Do you need the car on a lift or will jack stands do?
Old Nov 7, 2007 | 06:46 PM
SLVROZ_03's Avatar
Jack stands are all I have & they worked fine; just remove the front pass. side wheel.
