Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
heavy duty wire harness
Old Dec 3, 2007 | 02:43 PM
mines hotter's Avatar
i was intrested in buying high wattage bulbs (80 watts) and the heavy duty wire harness now will the harness prevent melting of the wires and everything and should i be concerned about the car drawing to much power and other components melting liek the headlight housing e.t.c
Old Dec 3, 2007 | 03:25 PM
evo_soul's Avatar
nokya sells a high wattage harness and a plug and play harness. I advise you to go the plug and play way, because cutting wires can be an issue with your warrantee should you have any problems.
they will run you about 15 bucks or less for the plug and play ones. 6 for the regular harness.
Everything else unless should be fine
Old Dec 3, 2007 | 03:54 PM
Blacksheepdj's Avatar
Rather than buy high watt bulbs, why not just buy good ones? Or an HID kit?
Old Dec 3, 2007 | 04:32 PM
SLVROZ_03's Avatar
Just buy Silverstar Ultras and be happy...
Old Dec 3, 2007 | 04:44 PM
ThunderOZ's Avatar
Yea I ran those for a couple years and then my harness melted...
Old Dec 3, 2007 | 08:10 PM
damnn truee yea well i was looking around and i think ill stick with the regular wattage bulbs i think im going to get the new luminics kypton in titanium white i had halo platiniums n the 1 burnt out so i sed f it they suck lol i have luminics jdm yellow fogs n there great
Old Dec 3, 2007 | 09:53 PM
brian360's Avatar
One thing to keep in mind if you're upgrading to higher wattage bulbs is the field effect transistor (FET) for the low beams. I have no specs on it, but its possible that you could burn it up by running too much of a load through it. If that happened, your low beams and DRLs would likely not work at all. Worst case (I doubt it'd actually happen, but if it fails like my old pinball machine's transistors sometimes fail, anythings possible) it would also fry your ETACS ECU. The FET is located under the engine-bay fuse box, the "Relay" with the big metal heatsink on it.
Old Dec 4, 2007 | 01:55 AM
razo's Avatar
that’s odd
especially because sylvania’s say they are legal for on road use and oem approved…
the main reason i find it odd is because when i took the oem bulbs out of my 08 lancer…they were sylvania’s…so upgrading to the sylvania silverstar ultras just seemed like the right thing to do. lol
Old Dec 4, 2007 | 11:40 AM
SLVROZ_03's Avatar
Yeah, ever since the Silverstars came out I've had them in all my cars. I have yet to upgrade to Ultras cuz my originals are still glowing strong! I even use the "trick" to illumniate both filaments, which I'm sure isn't good...but nothing better than low & high beams together to see in dark areas.
Old Dec 9, 2007 | 03:02 PM
CamShaft's Avatar
ok if you want to run 80 watt bulbs. Take 80 and divide by 12V to get the amp draw PER LIGHT. This is about 6.6 amps per light. You should be fine using stock wiring. Although it is bundled into the harness and get no airflow so it may get warm. The only way to do it properly I would think is install the bulbs and get someone to turn on the lights and feel the wire. Wait 20 mins or so until it might actually get warm, and it probably wont burn through.
At work I will wire in some trailer hook up lights for customers that are 50 watts a piece and I will use 16 gauge wire to run both. But 18 gauge, which I think is what our car has, will work fine to run each light separate. Good luck
Wire Gauge Selection Table 12 Volt Circuit
AMPS 3' 5' 7' 10' 15' 20' 25'
0 to 5 18 18 18 18 18 18 18
6 18 18 18 18 18 18 18
7 18 18 18 18 18 18 18
8 18 18 18 18 18 16 16
10 18 18 18 18 16 16 16
11 18 18 18 18 16 16 14
12 18 18 18 18 16 16 14
15 18 18 18 18 14 14 12
18 18 18 16 16 14 14 12
20 18 18 16 16 14 12 10
22 18 18 16 16 12 12 10
24 18 18 16 16 12 12 10
30 18 16 16 14 10 10 10
40 18 16 14 12 10 10 8
50 16 14 12 12 10 10 8
100 12 12 10 10 6 6 4
150 10 10 8 8 4 4 2
200 10 8 8 6 4 4 2
