Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
throttle body
Old Dec 29, 2007 | 09:36 PM
Noe18's Avatar
throttle body
is 65mm the biggest size you can put on our lancer
Old Dec 30, 2007 | 08:13 AM
Noe18's Avatar
any1
Old Dec 30, 2007 | 12:40 PM
ambystom01's Avatar
You can put a 100 mm TB on if you can get one made. If you're talking about the RRM TB, it's not 65 mm, it's 57 fluted to 65 at a specific point.
Old Dec 30, 2007 | 03:26 PM
Noe18's Avatar
how many mm is the stock 1, and do you know where can i get 65mm
Old Dec 30, 2007 | 03:36 PM
ambystom01's Avatar
Stock is 52 mm I believe. Why are you so set on getting a 65 mm TB? A bigger TB doesn't mean more power if you already exceed the limit of what the engine can bring in. The RRM TB is fine for their 300 hp drag car, I'm sure it'll be enough for your car.
Old Dec 30, 2007 | 03:40 PM
Noe18's Avatar
more air flow
Old Dec 30, 2007 | 03:43 PM
ambystom01's Avatar
That doesn't mean more power. If you hook a giant 100 mm TB to your car, it'll be impossible to drive since it'll lose the pressure advantage that keeps the air moving into the engine at a high rate of speed. Imagine trying to drink something with a 2" pipe for a straw. Theoretically you could take in more fluid with a giant straw but in practice it's so big you can't create a suitable vacuum.
Old Dec 30, 2007 | 03:46 PM
Noe18's Avatar
good point i see what you mean, how about a non turbo dsm 60mm, i think thats the max that i can go
Old Dec 30, 2007 | 05:14 PM
ambystom01's Avatar
Not sure if that can fit, I think it can but you'd best do a search on it.
