Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
How To: Rear sway bar
Old Mar 30, 2009 | 06:54 AM
EngRWW33's Avatar
yes, 20 mm
Old Mar 30, 2009 | 10:09 PM
humblehyper's Avatar
Ah ok thanks
Old Apr 1, 2009 | 10:44 AM
andres_d85's Avatar
Sorry about this; but can someone point me in the right direction? I'm trying to get a rear swaybar for my Evo IX but not sure on which one. Can someone send me the link to the right forum or anything?
Thank you!
Old Apr 20, 2009 | 10:31 AM
JoeyBallGame's Avatar
Update: Installation Complete
Old May 18, 2009 | 06:10 PM
orsabv31's Avatar
yes. all of them
Old Oct 22, 2009 | 04:56 PM
mguerrero's Avatar
09 lancer gts comes stock with a 20 mm sway bar
Old Oct 22, 2009 | 05:02 PM
mguerrero's Avatar
Originally Posted by mattchan99
I tried installing it yesterday. It was near impossible to get the end links off. Since both the stud and the nut were rusted, they were spinning together as i tried to unscrew it. How did you guys get yours off? I couldn't find a way to hold the stud in place, while trying to unscrew the nut. Please help!
Spray some pb-blaster on it and let it sit for like 20 min. then get your wrench and tighten it slightly with a hard jerk and that should help break it loose then try to loosen it
Old Oct 22, 2009 | 05:05 PM
mguerrero's Avatar
Did you get that done already?
Old Nov 9, 2009 | 08:51 AM
hdrasta's Avatar
will this work for any sway bar I just picked up the parrin sway bar on the GB
Old Oct 21, 2010 | 09:55 AM
M@verik's Avatar
Just curious what each setting does? From the instructions I got, the outer setting is more grippy and the inner tends to make the car oversteer. Is this correct?
Old Jan 28, 2011 | 12:34 PM
mrbloink's Avatar
I know progress auto makes a sway bar for the gts and the es but I cannot find anyone who makes a sway bar with hardware for the de. does anyone know who does?
Thanks,
Miles
Old Jan 28, 2011 | 10:44 PM
fredxclaus's Avatar
Thanks,
Miles
http://www.worksevo.com/store/produc...roducts_id=483
Old Mar 27, 2011 | 11:18 AM
Skooma's Avatar
For my next mod I am considering this Works sway bar, here at Fort Carson they have an Autocraft shop with vehicle lifts and every tool you could ever need to do anything. My question is, does the sway bar actually hold up any of the suspension? Maybe part of the problem these guys are having with the bolts and endlinks are from the weight of the car being placed on the sway bar? If so I would be able to just put it on the lift and raise it a little bit and throw this on.
Or, is it easier to just do it in my parking space?
Old Feb 13, 2015 | 01:01 AM
neverendingmods's Avatar
Nobody mentions the endlinks require an allen key placed in the stud to hold it while the nut is turned loose AND tight. Or it will just spin. Need to use an open end or box wrench. This is for stock endlinks front and rear.
Old Aug 14, 2023 | 03:43 PM
Nidos's Avatar
Is it the same, or a similar process for the front sway bar?
