Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
AFC NEO wiring to ECU harness for Automatic Lancer 2002
Old Apr 26, 2008 | 08:18 AM
rakillah's Avatar
After 7 hours of no sleep last night i figured out the wiring for the automatic. If someone else had figured it out already...then shame on you for letting the rest of the automatic guy hangout to dry by not posting it here. Well, with out further waiting, it's very simple just follow the wiring diagram provided in with the Apexi AFC NEO, instead of trying to follow the M3-A diagram or the never existing M7-E, use the
M6-A diagram. It refers to the mitsubishi RVR 4g63..BUT...the harness is the same, it utilizes the 3-row pin connector just like the 4g94 ECU harness. Just to show you in the picture below which connector is which, i have labeled the longest connect as connector #1, so use that diagram from LEFT to RIGHT. Wire and Play baby.
llDemonll
Sep 22, 2021 05:43 PM
blueo4
21
Sep 26, 2015 06:38 PM
alkatraz05
Apr 20, 2008 07:04 PM
BLK REX
Oct 4, 2007 04:30 PM
