How to delete out "Periodic Inspection"?
I change my own oil and do my own basic services. Just the other day on the console; everytime I start up my Lancer, the console "chimes" and it reads " periodic inspection." I am guessing that this is the reminder to have your vehicle serviced. Does anyone know how to delete this out of the menu or reset the maintenance intervals on your own? Thanks in advance!
Take it to the dealer to have it turned off with the MUT-III. They can also change it to a different mileage/month setting. You can reset it yourself using the info button.
With the key out & door closed, press the info button until the periodic service light is displayed. Press and hold the info button until it says clear. Press it one more time to clear the mileage.
Misutech: Thank you so much for the information. I figured I could just take it into the dealer, but have not had a chance to, so this is a great help! I appreciate everything!
You don't need to take it to the dealer, You turn it off using the info button to the left of the steering wheel. Its in the manual. It says to turn the car on but don't start it (ACC = ON) then push the info button until it shows the mile indicator with the wrench below it (on the center info screen) then press and hold the info button for a few seconds. The car will beep and the miles above the wrench will change/flash. This resets its.
BRO-
BRO-
BRO-
BRO-
So wait...the dealer can turn off the peridodic inspection schedule completely? This isn't something we can do ourselves is it? How much would it cost?
got a question, i just did my oil change, and the periodic inspection is gone now.
but instead of "xxxx" miles over x months in the display, it only shows x months? how do I fix that?
btw, i drive an evo, so i don't know if its the same.
I got the same problem here also! 6 months have past and my car haven't reach the 7500 miles check up...heck my car has only 2500 on it. Is there a way to change the 6 months period/7500.
yes, i just did it a few minutes ago, you have to clear it again, in my car (lancer 09 es) i did it 3 times and it reads 18 Months in the display.
Thanks a lot MITSUTECH , it was so anoying listen the beep warning each time i started my car.
Turning Maint. reminder on
Hello,
The service/maint. reminder on my multi function display is OFF. How do you reenable it? I have a 2008 GTS with the MMCS and R/F audio.
I have tried pushing the info button until the wrench flashes but not matter what I do after that it still says off.
Thanks,
Mike
Thanks,
Mike
