Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Cruise control light and Odometer light?
Old Mar 5, 2009 | 02:40 PM
BennettOZ's Avatar
Hey all, I was wonder how to change the lights for the Odometer and my cruise control, they both have gone out and though its not a "real" big deal, I would like to change them out. I just wanted to ask here first before I go tearing into my dash. Anything I should be aware of or watch out for while working on behind the dash?
Thanks
Old Mar 6, 2009 | 04:46 AM
Juan Martinez's Avatar
I would check all my fuses, both under the dash and under the hood before I done anything. Also, make sure you didn't just turn your dimmer down.
Old Mar 7, 2009 | 04:25 PM
BennettOZ's Avatar
I did check all of that Jaun.... Anyways, I got the lights out. No, How do I change the Cruise control light? it seems to be stuck in its little socket? I got the socket out of the dash panel just cant get the little light out of the socket.
Old Mar 7, 2009 | 04:34 PM
Now that I understand what your doing. They should just twist out. I took out some of mine on time, mainly the check engine light.
Old Mar 7, 2009 | 04:37 PM
BennettOZ's Avatar
Yep I got it to twist out, and now, that I have the little guy twisted out, how do I get the bulb out? or do I replace the hole twisty deal?
Old Mar 7, 2009 | 05:13 PM
BennettOZ's Avatar
It looks like the whole little light/socket needs to be replaced because the little wires wrap around the little socket deal... what size are these bulbs?
Old Mar 7, 2009 | 05:54 PM
I don't know where to get new ones, I'm sure if you go to a parts dealer, they are pretty cheap, I would say no more than a few bucks each. I think you get the whole thing, not just the bulb. I've replaced the bulb with an led before with a resistor on my eclipse. You should be able to go anywhere to get them. I should have a space cluster at home that has the bulbs in it if your interested.
RenosEVO
Feb 12, 2012 09:47 AM
shrtstuff89
May 8, 2011 07:49 PM
D1no
Mar 16, 2011 12:14 PM
living_the_drea
Lancer Troubleshooting
Mar 29, 2010 04:25 PM
justin.AZ
Oct 28, 2009 07:59 PM
