Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
RRM Front Upper Strut Bar
Old Apr 4, 2009 | 09:46 AM
JoeyBallGame's Avatar
Question RRM Front Upper Strut Bar
Can anyone tell me what size fastener is req'd to fasten the middle mount of RRM's Front Upper Strut Bar against the firewall using the stock threaded stud...?
Or
What size thread is the threaded stud that is in the center of the firewall to mount the center mounting point of RRM's Front Upper Strut Bar...?
Old Apr 5, 2009 | 04:06 PM
nj_08_gts's Avatar
M6
Old Apr 6, 2009 | 06:21 AM
Exclamation RRM Front Upper Strut Bar
I tried to install RRM's Front Upper Strut Bar and was unsuccessful. With no fasteners installed I was able to get the bar's mounting points over the studs, but didn't have enough room to get the fasteners on due to bad allignment, see picture attached...
Do I need to take the weight off of the suspension or pre-load the chassis by lifting one side... Has anyone run in to this...?
File Type: doc
Old Apr 6, 2009 | 06:45 AM
I Am God's Avatar
from what i know ur supposed to leave the car on the ground bearing weight as normal during the install...
Old Apr 6, 2009 | 06:50 AM
If that is true, then my car is out of tolerance or the bar is out of tolerance...
Any comments from Rock at RRM...?
Last edited by JoeyBallGame; Apr 6, 2009 at 10:26 AM. Reason: Modified statement...
Old Apr 6, 2009 | 07:45 AM
I Am God's Avatar
jus call em man..no harm in that, tell em ull email a link to the thread
Old Apr 6, 2009 | 07:52 AM
I sent Rock a PM... Thanks...
Old Apr 6, 2009 | 09:38 AM
MaRcO_GTS86's Avatar
you have to lift up one side of the car so that when you do put on the strut bar it'll be easier. if you don't lift the car you're going to have a really hard time putting it on. don't fully raise your car, but just enough to have some swivel movement
Old Apr 6, 2009 | 10:14 AM
Thank you for the advise, I will preload the structure for better re-allignment of the struts threaded studs... I'm going to have to wait for better weather due to living in a apartment complex... On my first attept, a guy from my APT complex asked me if I needed help... Come to find out that he is a Helicopter Mechanic and his suggestion was to lift one side, but I wasn't sure of that due to preloading the strut bar.
Again... Thank you...
What does RRM say about this...? RRM guys, any input...? (I hope so...)
Old Apr 6, 2009 | 11:12 AM
I Am God's Avatar
<--school is in session lolz
Old Apr 6, 2009 | 04:03 PM
ROCK's Avatar
Did you call us yet? The studs out of the strut just need a little nudge. As for the fastener, it is 6mm x .100. It should have been taped to the strutbar. Maybe it came off in the box. Just call and ask for Matt. He can help you. Once you talk to him it will be a breeze. IF they don't fit tight like it does a bar is worthless. Please call. that is what we are hear for.
ROAD/RACE
Old Apr 6, 2009 | 04:10 PM
I Am God's Avatar
so ROCK, does the car need to be lifted on one side for the install?
Old Apr 6, 2009 | 05:04 PM
Arrow Install...
ROAD/RACE
Yep, I called today at work... I was giving a little nudge, and with me was the, Thanks for helping me stranger walking by... And a aircraft mechanic, we both couldn't get that nut on the stud... I'm hoping that jacking it slightly will allow a little bit more help... Can't wait to have the time to get out there and it isn't raining...
I'm confident that I'll get it on, or Uncle Mechanic up state will get it on...
God Bless America
This Website has been very informative & enjoyable... Thanks to everyone...
Old Apr 20, 2009 | 04:31 AM
Status Update: Installed (Yippie)
Old Apr 20, 2009 | 07:03 AM
ROCK's Avatar
+1. Yippie.
ROAD/RACE
22raptor
Jul 2, 2012 05:18 PM
Brian@RRM
May 10, 2011 09:56 PM
ThirdGear
EvoX 'For Sale' Suspension / Brakes / Handling
Dec 6, 2010 05:07 PM
Anarchy
Dec 9, 2004 07:05 PM
