Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
re: 09 GTS with Ralliart Exaust?
Old Oct 15, 2009 | 07:34 PM
nvgtsguy's Avatar
Can this be done without too much effort? My buddy got new Exaust for his 09Ralliart today and gave me his - will it fit??
regards,
Old Oct 15, 2009 | 08:11 PM
dustyp34's Avatar
https://www.evolutionm.net/forums/la...a-exhaust.html
here ya go.
Old Oct 16, 2009 | 09:02 AM
nvgtsguy's Avatar
The 08 lancer and ralliart shared the same 2.0l engine. my GTS is a 2.4l will the downpipe be the same width?
Thanks in advance.
Old Oct 16, 2009 | 03:13 PM
dustyp34's Avatar
Bow that sir I don not know, but there is another way that you can get dual exhaust.
1. you can either get a one in two out muffler(such as a borla) and have a shop bend the pipes and such for you.
2. you can take the stocker off and gut the exhaust place a Y pipe adapter in the exhaust so that you have one inlet and two exits cut the whole for the other side and have the pipes bent(also you will want to stuff it full of insulation to cut down on some of the noise).
Neither the Evo or Ralliart have true dual exhaust the second option in a nut shell is basically what they have except with larger tips and pipping.
Hope that helped you out some.
http://www.borla.com/proxs/pages/muflrtrans.php
Old Oct 16, 2009 | 05:14 PM
CMcraz23's Avatar
we should get someone to do a true 2 exhaust.
Old Oct 16, 2009 | 08:26 PM
dustyp34's Avatar
here is what i mean with option 2: https://www.evolutionm.net/forums/la...-retrofit.html
Here is a dude that had a Y pipe custom job done: https://www.evolutionm.net/forums/la...stom-dual.html
and with this one you can get an idea what it will look like: https://www.evolutionm.net/forums/la...ouls-idea.html
