Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Megan Racing Gauges
Old Oct 24, 2009 | 04:44 PM
kmc8302's Avatar
Megan Racing Gauges
Just got megan racing gauges air/fuel, volts, oil press, oil temp and vacuum. Anyone install any of these yet and can spread some light onto how i do it, just trying to make it simpler and faster if possible, otherwise ill have to go exploring and figure it myself which will take longer than if someone has first hand experience! thanks in advancee. I really only need to figure out the oil press, temp and vacuum ones. The air/fuel and volts i can do easy.
Old Oct 24, 2009 | 04:58 PM
ambystom01's Avatar
Oil pressure- you can buy a sandwich plate that goes between the oil pan and the oil filter. Alternatively, you can tap the block.
Oil temp- same as above.
Vacuum- tap into a vacuum line coming from the intake manifold.
I'm guessing the A/F gauge is a narrowband?
Old Oct 24, 2009 | 05:45 PM
MasterAK's Avatar
What does the A/F gauge look like? Does it have an oxygen sensor attached to it? If it doesn't have it you might need to get a wideband oxygen sensor.
Old Oct 24, 2009 | 09:28 PM
kmc8302's Avatar
well the oil pressure gauge came with a oil pressure sending unit, I already hooked up the a/f and vacuum so those are up and running well. Its just does the 09 gts have a oil pressure sending unit i can replace or do i have to tap into it.
Old Nov 5, 2009 | 06:02 PM
notFSTenuff's Avatar
do you have any pictures? i was thinking about getting the same set up
