Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Taillight wiring harness
Old Feb 17, 2010 | 10:19 AM
itsjustinmeyers's Avatar
I just bought some oem taillights for my 03 oz to replace the ricey looking ones that were on it when i bought it. When i tried to take off the ricer tails it turns out they use different wiring then the oem's. Does anyone know where i can get wiring to match the oem?
Old Feb 17, 2010 | 12:22 PM
OZR_Lancer's Avatar
they should be the same plugs.. i replaced my oem tails with depo carbonfiber evo7 style tails and they connect to the factory harness... the tails come or should of came with the harness alredy attached to the tails... from their they just connect to the cars harness .. if they missing just take the harness off the other tails and use that harness on the oem tails.. their the same type
Old Feb 17, 2010 | 03:21 PM
Mine aren't the same. The aftermarket tails have 4 bulbs while the stock use only 3. Also the bulbs are a slightly different size
Old Feb 18, 2010 | 04:50 PM
OZR_Lancer's Avatar
dont see how thats possible.. can you post a pic
Old Feb 18, 2010 | 05:43 PM
It'll take me a little while to get a pic so ill just explain it as best i can. basically the aftermarket tails use a different set of bulbs than stock. they plug in to the factory wires. the aftermarket tails use 4 bulbs. i need a set of harness's like this
http://cgi.ebay.com/ebaymotors/2002-...item2a04d42d13
Old Feb 20, 2010 | 12:05 PM
OZR_Lancer's Avatar
i just checked mine... the oems have 3 bulbs [ turn, brake & reverse ]
the af ones, like my cf evo7 have 4.. they consit of turn, reverse and 2 brake lights = 4 bulbs
when you compare both tail lights oem and aftermarket together, both will plug into the car's oem harness as the plugs will be the same.... if u want i can get pics of mine
rodent
Oct 28, 2016 08:41 AM
ElectrIX Blue
Oct 5, 2016 11:54 AM
orugacoja
May 15, 2015 02:18 PM
Walter1986
For Sale - Part Outs
Mar 15, 2014 07:57 AM
MharAndal
Sep 8, 2013 09:01 AM
