toggle swith ignition
I dont know if anything like this has been posted before but if it has sry and pls oint me i the right direction. Anyways I want to replace my ignition with a toggle switch, is this possible? and if it is how would i go about doing that? thanks for any advice.
anything is possible, but just from the sounds of it, you would either need two switches, or a 3 stage momentary switch...you need to have one stage of the switch(or one switch) to supply the proper circuits with battery voltage, EI, instrument cluster ECU, EECU, radio ECU, ect. Then you need the next stage of the switch(or the other switch, make sure this is a momentary switch also) to supply voltage to the starter relay.
Is it worth it? I am a pretty good wiring expert on vehicles, and I would say its not worth my time, but if it is worth yours then... get a wiring schematic and a proper switch/switches then draw it out on paper (your personal schematic, in case something every f*cks up) then wire.
Good luck on this one
WTB[Northeast]: Need evo 8 shifter trim panel
HKSevolutionNYC
Nov 26, 2015 11:45 AM
