Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
toggle switch
Old Mar 17, 2009 | 11:08 AM
i786533's Avatar
toggle switch
question about toggle switches....
i looking for a specific toggle switch but dont know exactily what they are called...
i dont know if there is a toggle switch that can do what i want or if it will require other devices.
the following requirements
-switches a device on and off.
-device is off when engine is off (weather the switch is on or not)
-if left on and then engine is turned off defaults back to the off position
application~
two uses
inside LED
underglow kit
Old Mar 17, 2009 | 11:32 AM
kalpakiotis's Avatar
what are you trying to do with this switch?
It might be easier to find a suitable switch that way.
Old Mar 17, 2009 | 11:39 AM
D420mac's Avatar
wire it off a fuse!! A normal 12V toggle switch wired off a fuse, make sure it's a fuse rated high enough for your application (Fuse EVERYTHING!!!) or it's on the input side of the fuse, but be aware if the toggle switch is in the on position when you start your car it'll be on. if off it will be off no matter what. A relay, and switch combo may work better for your needs, I have no idea. What your trying to do. That information would help!
Old Mar 17, 2009 | 01:11 PM
i786533's Avatar
updated
Old Mar 18, 2009 | 04:39 AM
I'll think about it for a bit, u should be able to wire up a mini project box to do what you want, but i don't think youll find a switch that does it automatically unless its some switch integrated with some electronics.
I assume the underglow kit has its own power supply, the switch would just be the turn on.
Old Mar 18, 2009 | 11:28 AM
i786533's Avatar
what do you mean by a "mini project box"
what is that.??
Old Mar 19, 2009 | 05:00 AM
put a couple of electronics in a little black box. an easy way of doing what you want is to use one of those toggle switches that does not lock in any position other than the center position. Using an SCR, you can power it by using any power source that turns off when the car turns off. Then the toggle switch would be used to turn on the SCR gate which would provide power to any subsequent components. The SCR would then turn off when the car was turned off or when you pressed the toggle switch in the opposite direction to close the SCR gate.
Squatch
Dec 18, 2016 06:53 PM
cali11b
Apr 23, 2011 09:15 AM
David Buschur
Sep 15, 2005 08:00 PM
SICKdimension
10
Aug 27, 2003 09:52 AM
morphcivic
Aug 12, 2003 08:46 PM
