2011 Lancer GT HID RetroFit
Hey guys,
Owner of a 2011 Lancer GT (Canada), and I'm planning on getting the headlights retrofitted for HID's. I'll be using a set of Bixenon FX-R projectors.
I've looked through the How-To on disabling the DRL's (Which I need to do) however it seemed like there was some debate back and forth (For option 3) on which way was actually correct. Anyone have a concrete anwser on that?
However, I still need to wire it up for low and high beam operation, since they're bixenon. Has anyone on here done a bixenon retro? If so, how did you wire it up? I'm fairly sure that the lows switch off when the highs come on, so what are you guys using to activate the high beam solenoid, and keep the low beam on for the HID bulb?
Thanks in advance!
Thanks in advance!
