Sponsored by:
Sponsored by: CARiD
Evo x HID CONVERSION
Old Oct 25, 2016 | 06:59 PM
joonvang's Avatar
Hello,
I'm upgrading my base halogen headlights to projectors which will be using H7 bulbs. I will be getting the morimoto HID system. Now my question is this (see below)
1: will I need a CANBUS as apart of the HID relay?
2: Does H7 bulb come in Bi-xenon? The headlight company tht I bought mines from said the H7 will serve as low and high beam.
3: my 2015 Evo x does not have DRL so would I need the jrox cable thing or something in that ball park to stop the HID bulb from flickering?
Thanks
Old Oct 28, 2016 | 10:09 PM
gerikivan's Avatar
well you are gonna need a jrox for your aftermarket ballast hid but if your using the oem hid ballast the jrox wouldnt work on and you have to do the wiring method to disable the drl..
Old Oct 29, 2016 | 05:49 AM
splattj's Avatar
2: Does H7 bulb come in Bi-xenon? The headlight company that I bought mines from said the H7 will serve as low and high beam.
1: No
2: The projector has a shutter to do low/high / act as bi-xenon. H7 is two wires, IIRC, so it probably does not have a high beam trigger on it. You'd have to use the high beam power wire to trigger the projector shutter.
3. It doesn't? My '15 (with HID) has DRL. If you don't have DRL, you won't need the jrox cable
Old Oct 29, 2016 | 02:33 PM
Password_Vic's Avatar
Been using aftermarket hid'S for several years and always have a light go out... what's your luck?
Old Oct 31, 2016 | 04:09 AM
dorifuto.boi's Avatar
Used Denso ballast with Phillips bulb for years with no problems.
gqpenguin
Feb 4, 2017 05:50 PM
Nicdecdel
Jan 30, 2013 08:03 AM
iota
Midwest Region
20
Dec 1, 2008 08:16 PM
CT9AEvolution8
Jun 19, 2008 07:35 PM
NIGHTMARE
Mar 1, 2006 12:16 PM
