Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Changing Rotors
Old Aug 13, 2011 | 10:08 AM
sioux90's Avatar
Changing Rotors
I'm planning to replace rotors/pads this weekend on my 2003 Lancer ES, and will follow this guide, please correct if anything wrong.
I already painted some Duralast rotors with Duralast Gold pads (organic).
I'm under the assumption that the rotors are not bolted to the hub or anything like that.
1. Take off wheels front wheels.
2. Take off front calipers.
3. Take off rotors by screwing in two bolts in the rotors to push them out.
4. Replace rotors.
5. Push back calipers with a tool (open up the brake fluid cap - do not take any fluid out).
6. Replace pads with some lube on the back.
7. Replace wheels.
8. Brake a couple times really hard with various speeds.
Anything I'm missing or any extra steps I should take?
Old Aug 13, 2011 | 12:19 PM
WangMan's Avatar
Is number 3 necessary? I think the rotors can be pulled right off after the brakes are taken off.
Great suggestion taking the brake fluid cap off. I had a hell of a time pushing my calipers back in so that my new pads would fit, and it sounds like taking the cap off the fluid could help.
Old Aug 13, 2011 | 12:28 PM
FedEvo8's Avatar
Sometimes the rotors get seized on there. I couldn't get mine off without placing a bolt in the hole.
Old Aug 13, 2011 | 08:39 PM
sioux90's Avatar
I noticed some mild-moderate smoking/smell come from my left tire during the break-in period. How long should this last?
Old Aug 13, 2011 | 09:02 PM
CrAnSwIcK's Avatar
That's never happened to me, you sure it's the brakes?
Old Aug 14, 2011 | 09:08 AM
sioux90's Avatar
Taken from http://www.brakeandfrontend.com/Arti...the_rotor.aspx.
"If a brake pad set produces an excessive amount of smell or smoke on the initial bedding procedure, chances are that there is something wrong with the pad and how it was manufactured. "
Mine produced some smoking, but not an excessive amounts. I stopped a couple of times from 40mph to 5mph, and then 30mph and then 20mph. I also put some graphite anti-seize on the new rotors, maybe that is what is smoking, but it is high heat (800C). I'll test it again today.
