Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
timing belt install PLEASE HELP!
Old Jan 21, 2012 | 12:26 AM
Paintabruh's Avatar
hey everyone wondering if i install my under drive pulley on my lancer which is smaller do i need to replace my timming belt if so how do you replace it and do i need to do some sort of timeing with it? how do i do that? and what size belt? thanks heaps need help ASAP please im sure alot of use have done this so help will be appreciated
Old Jan 21, 2012 | 12:39 AM
Rog96's Avatar
from what I know from other engines is all an underdrive pulley does is slow down the assessories aka altinator, water pump, powersteering pump, and a/c but u only really need that if your running high rpms to save wear and tear on those. if these engines are different please let me know
Old Jan 21, 2012 | 01:18 AM
Paintabruh's Avatar
Aw nah haven't heard that I heard they are just light in weight and increase throttle response and hp gain, but wondering how to change timing belt and how to time it
Old Jan 21, 2012 | 02:31 AM
Paintabruh's Avatar
Man no one ever replys like on any thing thought this place was full of lancer enthusiasts
Old Jan 21, 2012 | 02:42 AM
JACS_06_MR's Avatar
if you are changing your crank pulley, you do not need to change your timing belt. if the pulley is smaller or larger than your factory one, then you will most likely have to change your belts. Most good aftermarket crank pulley kits will come with instructions saying what belts to use if they need to be changed.
FYI the point of the aftermarket pulley kits are to help the engine alleviate parasitic drag from all the accessories like your a/c, alt. etc..
Old Jan 21, 2012 | 02:53 AM
Paintabruh's Avatar
Wait I'm confused you said I will not need to change timing belt but then you said I do? I'm getting mine from cosmo racing seems legit they are very helpful and think they said I will have to change my belt and I'm guessing would be thd timing belt, and I'm thinking it going to be difficult to change and time the belt am I right?
Old Jan 21, 2012 | 08:43 AM
Rog96's Avatar
not timeing belt ull have to change your serpitine belt (the one that is on the outside of the engine that powers the assessories) hope it helps
Old Jan 21, 2012 | 01:56 PM
Paintabruh's Avatar
Aw sweet yeh mate helps alot so that one needs no timing? And that's the one you can see aye?
Old Jan 21, 2012 | 02:13 PM
Steven's Avatar
Your timing belt doesn't ride on the under drive pulley. The timing belt rides on a sprocket under the plastic timing cover. The under drive pulley is attached to the crankshaft on the outside and your serpentine belt rides on it.
Old Jan 21, 2012 | 02:27 PM
Paintabruh's Avatar
So all I do is change that one no timing of it at all mate?
Old Jan 21, 2012 | 02:44 PM
Steven's Avatar
That's it. Take off your serpentine belt and remove the crank bolt. An impact makes life a lot easier.
Old Jan 21, 2012 | 02:59 PM
Paintabruh's Avatar
How do you take the belt off? And then put new crank on and the smaller belt done?
Old Jan 21, 2012 | 03:06 PM
Steven's Avatar
If your tensioner is like the Evo, you stick a 3/8 squared end of a ratchet in the hole and turn clockwise to take tension off the belt. Slip the belt off the crank pulley. Use a 1/2 drive impact and stick the square end in the crank bolt and back it out. Pull off the crank pulley. I have no idea what size belt you would need to use for that new pulley.
Old Jan 21, 2012 | 03:13 PM
Paintabruh's Avatar
Thank heaps man real help finally get a good thread going I can never find out stuff really appreciate it
Old Jan 21, 2012 | 03:14 PM
CrAnSwIcK's Avatar
It's not even close to the Evo...the 4G69 is similar to the 4G63 in that regard, but the 4G94 is quite different...
