Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
2011 Lancer ES 4B11 Engine
Old May 16, 2015 | 01:22 PM
Tribute3's Avatar
Hello all,
I have a few questions since my last visit to Mitsubishi service.
I have an 2011 Lancer ES with 92 000 km. He suggested a fair bit of work below.
1) Recommended fuel induction/throttle clean service Do you guys do this? He mentioned that the fuel will build up internally and affect power and efficiency.
2) Recommended PCV valve replacement.
3) Recommends engine coolant replacement. How often do you guys do this?
4) Recommends manual transmission fluid replacement. How often do you guys do this?
5) I'm told this car has a timing chain. Do I need to replace it and at what mileage?
Total cost of items 1,2,3,4 is over $600.
Thanks for any replies!
Old May 17, 2015 | 10:30 AM
Tribute3's Avatar
Does anyone have experience with these?
Old May 18, 2015 | 02:57 PM
Etrain49's Avatar
I would do it if I were you, the biggest cost of that is the transmission fluid, definetly do it if it's due
Old May 21, 2015 | 07:54 AM
Veronica's Avatar
My questions to your questions (and not in order - just my thoughts):
1. What does the Owner's Manual say? Find the maintenance interval table and unless you are 'severe driving profile' assume the normal schedule. There is no reason to deviate unless required. It really sounds to me like the shop is just drumming up more business from unsuspecting or people lacking in knowledge. I am glad you asked the forum.
2. What is your fuel economy now? Has it decreased any?
3. Modern fuels all have detergent (even the lowest grade). An injector cleaning is only required when performance or fuel economy suffers (and you have checked the obvious stuff like air filter and tire pressure first).
4. Yes, you do have a timing chain and no replacement is necessary (like a timing belt which does have a change interval) unless indicated by a check engine code for timing chain stretch.
So. Be an informed customer on your next visit Please consider using another dealership or garage in the future. The one you went to sounds shady to me.
Bandu1
Lancer Engine Tech
Oct 6, 2017 12:44 PM
Ronaldo95163
Oct 2, 2014 02:42 PM
sirchumpalot
12
Feb 27, 2013 06:51 PM
evo-monstar
Lancer Engine Tech
Jul 29, 2008 08:30 PM
MITVRX
Lancer Engine Tech
Jun 2, 2007 06:59 AM
