Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Lancer exhaust system help
Old Aug 21, 2016 | 07:22 AM
Logkell10's Avatar
I have an 02 Lancer Es, and as you know the oem headers come attached to the cat. I only have one cat, which is the front one, could I just buy new headers and a new cat to replace the oem ones or would there be some sort of issue.
Old Aug 21, 2016 | 12:23 PM
CrAnSwIcK's Avatar
Your wording is a little off...the 4g94 has 2 cats, one integrated in the exhaust manifold, and one regular cat. If you get aftermarket header, you will get a check engine light, so you'll need to trick the first sensor (spacer), or reprogram the ECU. Depending on where you live this may cause issues with emissions testing.
Kambochris
Sep 4, 2016 12:51 PM
PsychDr. HN$
10
Aug 4, 2008 04:39 PM
Quickshift
Oct 10, 2004 07:49 AM
sthiewes
Jul 20, 2004 09:02 AM
vespa
Australian Forum
Mar 12, 2004 03:20 PM
