Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Cylinder head shave
Old Mar 10, 2026 | 02:05 PM
slayer2009's Avatar
Cylinder head shave
I was curious if yall got anywhere with shaving the cylinder head down on a 4g94 I知 curious to do so and if it caused any problems, if I知 in the wrong place I apologize, Lmk
Old Mar 11, 2026 | 09:46 AM
schuhie's Avatar
Define "get anywhere"? You can definitely get the head surfaced but what is the goal?
Old Mar 16, 2026 | 01:40 PM
mitsuatb's Avatar
If the head and block are shaved you disrupt the timing mark alignment used to install the belts. Because the cams centers move down and crank Center line doesn't move. You would be better off sourcing taller pistons to increase CR and only touch the head or block to make them flat.
High CR reduces the amount of boost you can run. If peak power is your goal bigger turbo will help more than CR. Balance of power might be helped with more low end from higher CR but peak power will suffer.
RS Motors could advise you better than me.
Old Mar 23, 2026 | 07:49 AM
slayer2009's Avatar
Okay I definitely see now, not worth it, only reason I say is I plan on keeping N/A due to the fact I知 a auto trans but I know everyone on here recommends a turbo but would the head swap be worth it for what all must be redone, or is the turbo worth it on a auto trans even, i壇 imagine I壇 be better off building a separate engine and js doing a manny swap
edit: when I mean the head swap I知 referring to the mivec head
TJ03VIII
Southeast Region
Mar 15, 2025 12:11 PM
Headgames Motorworks
Feb 1, 2014 05:37 PM
nismo3183
Nov 16, 2013 08:11 PM
