Lancer How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in in the Request sub-forum.
How To: tap water lines for 16G turbo set up
Old Nov 4, 2008 | 11:31 AM
lncrphish's Avatar
Just thought i put this out for people doing custom turbo setups. I have received a lot of questions about this so Here it is in easy to understand instructions.
You want to get (2) T-fittings (not sure on the size but just look at the hose) You will need some clamps about 8 of them. you will need about 4 feet rubber hose.
First find your water lines. They will be under the throttle body. One goes in and one comes out. Look in this pic below. Cut the first hose, insert T-fitting and new hose that goes to the turbo. It does not matter which one goes into the turbo. They are not directional. Then do the same for the other hose and you are done.
drb
53
Oct 25, 2016 07:50 AM
ithveno339jfkj4kjekjqqqq
Apr 10, 2012 05:01 PM
turbotaloon95
Oct 19, 2011 04:20 AM
yitzac1990
34
Jan 12, 2010 04:35 PM
SzuChenEvo
15
Dec 20, 2003 02:19 PM
