Lancer How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in in the Request sub-forum.
Disabling DRLS on 2008+ Lancer
Old Jan 2, 2009 | 06:24 AM
08Lancer89's Avatar
okay heres what I did,
you are going to need these supplys,
2 40 amp releys
wire Cutter/strippers
proper fittings
Zip ties
wire, About 2 feet.
1 hr max time lol
YOU WILL HAVE TO CUT 2 WIRES IN EACH HEADLIGHT
I took the Blue Wire going to the parking light the little amber blub or led you have and spliced it, the I cut the red/white wire going the the lowbeam. heres the Diagram below so you know what im talking about. Very Simple. this cut out all of my lights, when I turn the switch 1 time it puts the drls on along with the parking lights, 2 click is full lights, and fogs are the same..... time for HIDS!
the black box is the back of the reley
Old Jan 2, 2009 | 07:09 AM
08Lancer89's Avatar
Here are a few pics of the finished product...
Passenger Side was tricky, not much room but it got done....
this is the Drivers side... it was easy
Old Jan 2, 2009 | 07:57 AM
eyekyu's Avatar
so this was done w/o hids?
Old Jan 2, 2009 | 08:43 AM
08Lancer89's Avatar
for the time being yes, but I am getting my HIDs today or tomarrow, and I will let you know if it works, it should becasue It cuts out the drls....
Old Jan 2, 2009 | 09:18 AM
jRox's Avatar
cool man, you figured that out yourself?
hopefully they should work with the HID's. I don't see why it wouldnt if they are already de-activated without HID's.
Old Jan 2, 2009 | 09:31 AM
Answer_1's Avatar
From my understanding, you will still have the HID flicker problem if you just put power the parking lights and you don't turn the switch 2 full clicks. Turning the switch to parking lights is gonna be exactly the same as if you don't have any relays installed.
But of course, this problem is easily solved if you don't use the parking lights only feature (quite a few people like this feature so I wanted to point that out).
But good job man. Easy way to disable DRLs!
Old Jan 2, 2009 | 11:40 AM
08Lancer89's Avatar
thanks I have releys and with my HID kit I bought the Battery Reley power supply harness. well see right now im looking at it with my dad i am a bit confused. But my friends going to come over and check it out.
Old Jan 2, 2009 | 03:51 PM
08Lancer89's Avatar
It works with hids!!!!! Yes!!! This is a fix! For drls and hids ! Enjoy!
Old Jan 4, 2009 | 05:42 AM
08Lancer89's Avatar
and yes when I click the light switch one time my hids flicker, anyway I can fix this? but its sort of cool lol like strobe lights. But when you do 2 clicks it works just fine!
Old Jan 4, 2009 | 11:57 AM
crf450mxer's Avatar
I wish some one would figure out how to disable the DRL's and be able to use just your parking lights when you want to. I miss being able to do that, oh well glad I found this because I was just going to splice into my parking lights for my hid's.
Old Jan 4, 2009 | 01:23 PM
08Lancer89's Avatar
you can still use your parking lights when the car is off and parked. But when its on with this way that I bypassed, its like the DRLS so the hids Flicker in postion 1, but not 2 so its all good
Old Jan 4, 2009 | 01:40 PM
STItoEVOX's Avatar
That's F'n awesome man, good job. Now if I could only find the oem HIDs for less than $1300
Old Jan 4, 2009 | 05:03 PM
08Lancer89's Avatar
thanks man, it was not hard at all very easy only cost about 15 dollars to do to
Old Jan 4, 2009 | 05:04 PM
08Lancer89's Avatar
thanks dude
Old Jan 26, 2009 | 05:29 PM
08Lancer89's Avatar
tada
