Lancer How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in in the Request sub-forum.
How to: install B&M short shifter kit
Old Nov 16, 2010 | 03:56 PM
mci2727's Avatar
So I installed a B&M short shifter in my car and am very impressed with the instructions that came with it.
I'll post them here with my own notes included.
I chose the 45186 kit which is the adjustilbe shifter, either 15 or 45% reduction your choice.
The kit includes;
shifter, metal base bushings, locktight, grease, all hardware needed for install.
Note; The stock Lancer shift knob will not fit on this shifter after install.
The stock knob can't go down far enough on the shifter to screw on it.
You'll need a new knob, m10x1.25 is the size you need.
You will need a dremle or something to cut the shifter base if you choose 45% reduction.
Here is the instrutions:
And here are before and after shots.
Bfore with stock knob
After with stock knob
After with Blox knob
Close-up of Blox knob
This shifter at 45% makes the bottom section longer then stock and the top shorter, a true short shifter.
It makes a big difference!
I drove the car first with the stock knob (doesn't thread on) on the B&M shifter and it was good.
Then I installed the Blox knob and wow!
A big differece.
The 450 grams really put some weight into your shifting and made it about half as hard to put it in gear.
You should get the B&M shifter but even if you keep the stock shifter, get the Blox 450 gram shift knob!
Total job time: about 2 hours
Job difficulty: easy to moderate
Old Nov 20, 2010 | 01:26 PM
mci2727's Avatar
Updated with fallow-up pics.
Old Nov 20, 2010 | 01:55 PM
yahh's Avatar
Great how-to
Old Nov 26, 2010 | 12:18 AM
mci2727's Avatar
Originally Posted by yahh
Great how-to
Thanks bud.
I thought it was about time damn time someone did a write up on this.
And wish I knew the few steps I threw in there.
Old Jan 30, 2013 | 10:06 AM
HAPPICAKES's Avatar
i WISH I HAVE SEEN THIS EARLIER ! ! ! exactly same thing for the EBAY shifters posted by another forum nice chap !!
mci2727
Jan 23, 2017 08:46 AM
grimrpr9
Jan 28, 2014 06:36 PM
mci2727
Apr 1, 2012 08:52 PM
ssg_petty_210
May 14, 2011 05:29 PM
mci2727
Dec 15, 2010 03:36 PM
