Lancer How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in in the Request sub-forum.
4g64 swap questions.
Old Oct 13, 2014 | 11:15 AM
jb988's Avatar
I'm wanting to do this swap this summer but I'm confused on what I need. I have a 2003 lancer. A/t transmission. I had wanted to go forced induction.but after tearing into my engine the past couple of months with new timing belt and water pump and other maintenance I got the bug to do more the n/a route. I see the 4g64 as being promising. But I have read tons and I'm still confused. Hopefully people can chime in with guidance
I know I need the 4g64 but confused what vehicle I may get it from and what transmission I may use.
I am also confused on accessories for the new engine and if the 4g64 will connect correctly to the stock exhaust.
Also ecu? Does it have to be from the same vehicle I pull the engine out of? And does it plug and play like the stock lancer ecu?
And finally the custom mount? Is it the pass anger side? I've read three articles for the this swap but I Rember seeing somewhere that you needed 2 custom mounts.
Old Oct 17, 2014 | 02:48 PM
Thahomeboyb's Avatar
I also own a automatic lancer , the 4g64 motor can be pulled from a 00-05 mitsu eclipse . I beleive you have to get the harness from the same car but I could be wrong . But having the wires from the original car cant hurt . Also I think you need an ecu aswell .
Old Oct 20, 2014 | 10:31 PM
Jsangiovanni's Avatar
There are a few different cars you can get the motor out of. Mainly eclipse as stated above and also galants. And if im not mistaken monteros have them aswell. You will need to do a manual transmission swap i have not seen an auto swap done with that motor yet. I do not know about the exhaust tho. Harness will be from the car you pull it from. And ecu aswell. Should be a plug and play situation when you have the motor harness and ecu. And as for the motor mount you only need one the passenger side mount custom made. If you look under the forced induction section cfr has a build labeled "beastly 2.4 build" (something like that sorry im doing this on my phone so i cant go back and forth with links) but he has specs for the mount on there and all the info you need on this build in detail.
Old Oct 21, 2014 | 07:13 AM
Has anyone done a 4g63 becuase I know thats what the eagle talon uses and there some do come in automatic
Old Oct 22, 2014 | 09:42 PM
I kno that the 4g63 and 64 have the same mounting pattern for the transmission. So i dont see why you couldnt use a 63 block and a eclipse tranny. For automatic i guess you would need to actually try and see if it would work noone ive seen has done it. Everyone does it with manual trannys. Bt the principle is the same you just might need a custom mount on the driver side also. The biggest issue would be axles tho. Trying to find out if you could get the axles to work
djikonatx
60
Sep 13, 2013 11:08 AM
howell
Jul 4, 2013 08:37 PM
mrboost05
Mar 6, 2013 09:58 AM
bostonhatcher
26
Oct 10, 2012 08:33 AM
djikonatx
164
Jun 20, 2012 08:02 AM
