Lancer How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in in the Request sub-forum.
Replace brake pads
Old Apr 18, 2004 | 05:05 PM
neilschelly's Avatar
Replace brake pads
So I just installed the Axxis pads from RRM and took a few pictures to show others how simple a service brake pad changes are. I'm assuming y'all know how to safely jack up your car and remove a wheel.
Here's the first picture, which is essentially the wheel hub, disc, and rotor after taking off the wheel. The important part to notice here is that there are two big bolts on the top (??mm) and bottom (14mm) of the caliper. Unbolt the bottom one and continue to the next picture.
Old Apr 18, 2004 | 05:08 PM
After releasing the bottom bolt, the caliper will swing up like shown here. The pads themselves are clipped to the stationary part of the caliper and can be readily popped out now.
Old Apr 18, 2004 | 05:12 PM
So here's the same picture again with the old pads removed. And they'll likely come separated from their backplates while doing this. Each pad has a clip at its top and bottom to hold it to the stationary part of the caliper and also to keep the pad from bouncing around too much inside the caliper. Don't lose these, but if you happen to, it's probably not the end of the world. I imagine you'll get some squeaking though.
Old Apr 18, 2004 | 05:17 PM
Now, you see the new pads in place of the old ones, just clipped into the same spots. It took a bit of maneuvering work to get them into the clips, but it's not too hard.
More importantly, at this stage you'll notice you can't get the caliper to swing back into place and the fault lies with the piston. The large round hole in the back of the caliper is easily visible in this pic and that's the piston. You have to push this back flush against the caliper again, but don't expect it to move quickly. You can buy/borrow a caliper spreader to make things easier, you can use the old pads and a crowbar if that suits you. Personally, I just push the old pad against it with my hands until it's flush, but I suspect some people won't be able to do that - no offense.
Old Apr 18, 2004 | 05:20 PM
Once the caliper's piston is pushed back, you'll be able to fit the caliper back in place over the pads - it should be a tight fit, but it'll get on there. Before putting it all back together though, use some brake lube, available in tiny packets for $1 or so at any automotive store, and coat the outside of the pads with it. DO NOT get lube on your pads' friction surfaces or the rotor, for obvious reasons. The lube is just used to prevent noise from the pad moving around in the caliper itself.
One note to be careful of is that while I was pushing the caliper back into place around the pads, the back plate on one of the pads broke free of the pad. It's just glued on there really, and not too strongly, so just make sure if that happens to you that you position it correctly back in place before closing the caliper.
Old Apr 18, 2004 | 05:25 PM
Final step is to put back the bolt you took out at the beginning. It had a small black rubber tube it went through which may need to be coerced between the stationary and swinging parts of the caliper again, but again, it's not tough. Tighten that bolt and replace the wheel and you're done.
Get into the car and pump the brakes a bit. This willl help make sure the brake system is properly pressurized and the calipers are floating in the right place. You may find your new pads are a bit weak at first. Bed them in slowly by repeatedly stopping from 30MPH tops until they feel better. Don't slam them and don't overheat them - just gently work them in a bit for a few minutes and they should feel nice and strong again.
This process is probably not much different on any Lancer, Evo, Ralliart, or any other car for that matter with disc brakes.
Hope someone enjoyed reading this far ;-)
-N
Old Apr 19, 2004 | 08:25 PM
LancerEvoMR's Avatar
Discuss thread here
jdizzy204
May 19, 2012 07:36 PM
Jixxer
Mar 5, 2008 11:55 AM
rice_rocket88
22
Sep 6, 2006 08:06 AM
bbradj
Jul 18, 2005 07:00 AM
RyanShanley
Lancer Troubleshooting
Oct 30, 2002 10:41 PM
