How To: Install a Evo X ecu on a NA Lancer.
So you have boosted your lancer...
This is for 2008+ 5 speed Manual Turbo Lancer. First thing to do is to flash an Evo X rom into your Lancer Ecu. If you are not able to flash your rom in the car, you must remove your ecu and do a bench flash. If you are not able to bench flash the evo x rom, you have to use an older EcuFlash version. The best Version to bench flash is Version 1.43. The newer version will only flash roms with the same first 4 digits. For example: If your car original rom ID is: 54410003, it will only flash rom IDs that's start with 5441... With the 1.43 Version, you can flash any rom into any ecu. Remember, when you do a bench flash, you must do it in recovery mode first and then flash it in normal mode. Edit: The last EcuFlash 1.445 is capable of flashing any rom into any ecu. You can start tuning the car. At this point, you will have few DTCs. P0365 Mivec Ex. actuator, P0098 IAT sensor, P0242 and P0243 Boost control solenoids. Your MIVEC will not work because of the P0365. The only way to get rid of that DTC is using an EVO X Ecu. If you want your Mivec back, you need an EVO X ecu. You can get the ecu from any year GSR or MR (2008+). Once you have your Evo X ecu, you have to go to the dealer and do the programming with the MUT-III. With the MUT-III, copy the ECU Coding from the Lancer to the PC. To do that, you have to clear the DTCs, if there is one DTC, it will not work. I had to install the IAT sensor because the P0098 was always there and I wasn’t able to clear that code. The P0243, P0242, P0365 can be cleared and if you don’t start the car, they will not show up. On the MUT-III: Sys select Select MFI Coding Save to file Install the Evo X ecu. Write the VIN into the Evo X ecu. On the MUT-III: System select KOS/IMMO/Keyless Special function ENG Key Code &Chassis No/VIN Reg Enter the chassis VIN you want to program the ECU to Paste the ecu Coding from the PC (previously saved from Lancer Ecu) to the Evo x ECU. That will avoid having the U0121 DTC. It tells the ECU that your car is 2WD with a Manual Transmission and has for example: the ABS or ASC and so on. On the MUT-III: On vehicule Coding Enter Your VIN Select the file Clic on Check icon Clear all the DTCs Flash your tuned rom on your new Evo X ecu. Your Mivec will work again, the engine will be smoother and you will gain power. If you want to get rid of the P0243 and P0242, you will have to install the two boost solenoids from the evo. And Voila! |
My dealer said that the ecu and the car weren't communicating. But at the tuner we were able to put different flashes on it. I don't understand
I have a evo ecu btw
Originally Posted by TheOtherLancer
(Post 11403032)
Originally Posted by sebass007
(Post 11403359)
I think it's because they don't know how to do it.
At this point I'll rent an MUT III and do it myself. I just want to confirm that this indeed works before I spend the money. Thanks for the help in advance. |
Originally Posted by Twylyt
(Post 11409875)
Went to the dealership today and was told that it wasn't possible to change this. Even told the tech that others had done it and he still stuck to his story. He blamed it on how the EVO ECM was built or something. After hearing this I realIzed that he had no clue.
At this point I'll rent an MUT III and do it myself. I just want to confirm that this indeed works before I spend the money. Thanks for the help in advance. http://etacsdecoder.com/index.php |
(Post 11409994)
There is another option. You can buy a Actia XS and change the engine ecu coding.
(Post 11410595)
I'll have to look into that. Have you used this before? Do you know if it's as straight forward as the MUT III? Thanks again for your help. After all this work I'm looking forward to being CEL free....and being able to use my cruise control again.
My evo x ecu started my 4B11T GTS. This worked just fine for me but I got other codes to deal with. P0365 is def gone and my MIVEC should be working as soon as I get rid of the other dtcs, but I'll keep you posted. It never ends lol
Originally Posted by BKGTS22
(Post 11450693)
Where can someone rent a MUT III scanner? And Im having the same problem with my dealer. He plugged in the ECU BUT i dont think he cleared the codes first like stated. About the Actia XS is that just as easy? When he was putting the vin in he was able to but the car wouldnt turn over when we were trying to start it. Any ideas?
(Post 11459712)
(Post 11459782)
Did he do it exactly like I did in this thread? You have to keep an eye on them because this is something that they don't do often...
P2128 is there then I clear it but instead of actually clearing the code changes to P28B then I clear it again and it changes P2100. I think my ecu is on the fritz. I'll try to redo the steps at my shop and give them your instructions since they have the MUT III
Can I use EcuFlash to write the file from the Lancer ecu to the Evo X ecu? Or do I have to use the MUTIII?
