Lancer-Mirage Compatibility Forum For parts that can be used on both Lancer & Mirage models, post/look in here.
Lancer/Mirage New Engine Build
Old Jun 2, 2009 | 06:30 PM
phlouse's Avatar
Well have started my new engine build a few weeks ago and am almost in the completion phase of the installation. I have a Mitsubishi lancer 1998 know as a mirage in the US. I have a 1.6 SOHC 16V
parts for the build
PAR con rods
CP Pistons 8.5:1
Tial 38mm wastegate
Tial 50mm blowoff Valve
PWR barrel liquid to air intercooler
ACT extreme 4puck
SC 6162RE tubro
3inch down pipe
RPW rear disc brake conversion
Cryo treated front disc
KYB AGX front and rear shocks
Ground control coilovers
Jun 5.1kg flywheel
ARP studs
Head port & polished + cc'd
Adjustable cam sprocket
RPW Stage 2 camshaft
RPW valve springs + shims
Haltech E8 + patch loom
Haltech boost solenoid
3Bar map sensor
Aeromotive fuel pressure regulator
255 intank pump + Bosch 044 inline
-8an delivery fuel + -6an return fuel lines
White line rear sway bar
whiteline front strut bar
KAAZ 1.5 lsd
Sparco 13inch steering wheel
Gauges egt, oil px, boost, water temp
innovative Lc1 + xd16 gauge
Precision 750cc injectors
Oil/air seperator
There might be some more but I can recall right now. Well here are a few pics
[IMG][/IMG]
This is my log manifold made by a gut name Flynt from mirage forums.net
[IMG][/IMG]
750 cc precision injectors
[IMG][/IMG]
RPW rear bake conversion
[IMG][/IMG]
PAR con rods
[IMG][/IMG]
PWR barrel intercooler
[IMG][/IMG]
CP Pistons
[IMG][/IMG]
[IMG][/IMG]
SC6162RE Turbo
[IMG][/IMG]
Slimline fans
[IMG][/IMG]
Autometer gauges
[IMG][/IMG]
Ground Control coilovers
[IMG][/IMG]
KYB AGX Shocks
[IMG][/IMG]
Whiteline sway bar + strut bar
[IMG][/IMG]
Expospeed slick package 13x8.5x23
[IMG][/IMG]
255 walbro
[IMG][/IMG]
Piston and rods assembled
[IMG][/IMG]
Honing job
[IMG][/IMG]
Pistons installed
[IMG][/IMG]
Cumbustion chamber polished and cc'd
[IMG][/IMG]
Intake port & polished
[IMG][/IMG]
exhuast port & polished
[IMG][/IMG]
fuel lines
[IMG][/IMG]
fuel lines + inline filter
[IMG][/IMG]
tank with lines installed
[IMG][/IMG]
Bosch 044
[IMG][/IMG]
shot of adjustable cam sprocket
[IMG][/IMG]
checking turbo fitment + oil drain line
[IMG][/IMG]
RPW patch loom harness
[IMG][/IMG]
E8 in the car
[IMG][/IMG]
A/F nice this is with the standard engine did some minor tuning
[IMG][/IMG]
Gauge page again this is before i started the build
[IMG][/IMG]
zero setting the cam using centerline method
[IMG][/IMG]
PWR barrel radiator
[IMG][/IMG]
ACT clutch 4puck[IMG][/IMG]
engine installed [IMG]
[/IMG]
downpipe + wastegate pipe
[IMG][/IMG]
Almost finished
Old Jun 3, 2009 | 12:55 AM
Evo666's Avatar
Looking good, I can't wait to see the finished results with dyno charts
Old Jul 14, 2009 | 10:54 PM
link62's Avatar
so any updates on this i hope he gets back on
Old Jul 14, 2009 | 11:31 PM
Juan Martinez's Avatar
Subscribed
phlouse
Feb 6, 2017 05:05 PM
97TSiAWD
For Sale - Cars For Sale
20
Jul 16, 2011 08:59 PM
theghost
May 14, 2008 05:18 AM
tookinkee
Apr 20, 2008 10:39 PM
tookinkee
Oct 29, 2007 07:23 PM
