installing aftermarket headunit - HELP!
Old Nov 27, 2006 | 11:49 AM
gjgfrombigd's Avatar
What's up everyone. Just got a 7" in dash dvd system to install in my '04 ralliart with the Infinity system. I was told that I have to bypass the amp since the stock headunit has no power to the speakers. Do I need a powerless unit to integrate to the existing amplifier? Is it possible to still utilize the stock amp?
Any help would be awesome.
Old Nov 27, 2006 | 01:32 PM
eruslobo's Avatar
it is strange that one in dash dvd player doesnot have output for the speakers. well in that case use the rca outputs and plugthem to the amp the to the dorr speakers, no more unit is needed. amout the stock amp please tell more about it the what plugs have high level or low level?
Old Nov 27, 2006 | 02:01 PM
graphictor2's Avatar
get a wiring harness the only thing i know that amp powers is the opt sub if you have it but if you hook it up right you dont haft to bypass it the system should play through it from what i have been told in the past but look at the spec on your car it will tell you if you have amp and sub in your car what dvd indash did you get
Old Nov 27, 2006 | 02:04 PM
The unit I bought is powered but I was told that the Infinity head unit that came out of the car is not powered. I was told that I have to wire the new unit to all the speakers bypassing the stock amplifier that is under the seat. I was wanting to utilize that amp, but the plug for the amp is proprietary.
Old Nov 27, 2006 | 02:07 PM
do you have a wire harness for the aftermarket deck that you wire up to you aftermarket radio if you do you can hook it all up
if you need to bypass the amp look for a amp bypass kit most audio stores have them but you should be able to run it with the amp in the car
Old Nov 27, 2006 | 05:46 PM
otter's Avatar
EvoM Administrator
Originally Posted by gjgfrombigd
The unit I bought is powered but I was told that the Infinity head unit that came out of the car is not powered. I was told that I have to wire the new unit to all the speakers bypassing the stock amplifier that is under the seat. I was wanting to utilize that amp but the plug for the amp is proprietary.
You can use the new headunit to send the signal to the factory amp under the passenger seat. Use the below adapter to plug the factory amp into your new headunit's pre-amp outputs.
http://www.soundgate.com/index.php?r...usereferrer=1&
Old Jan 1, 2007 | 11:36 AM
Thanks Otter. I would have never found that. Bad news is, I already returned the headunit. Good news is, I know now that I can use any headunit with the stock amp.
Thanks for the help.
Just curious, does anyone know if the sideskirts on an evo are the same as the ralliart. WTB some side spats but the seller doesn't know if they'll fit the '04 ralliart. They're for an evo VIII.
Old Jan 1, 2007 | 11:41 AM
otter's Avatar
EvoM Administrator
It'll fit. Both cars use the same sideskirts.
Old Jan 1, 2007 | 11:44 AM
bigric09's Avatar
thats the same one i used for my install... it works great
Old Jul 18, 2007 | 08:52 PM
byc_panty's Avatar
hey for that adaptor...
how come it looks like it wont fit in my cars new deck??
(im not talking about the four plugs but the other circular one)
Old Jul 19, 2007 | 09:45 AM
If you have the S&S package (with the sub and amp under driver's seat) The circular end of the adapter plugs into the cable coming up from the amp. Then, the rca's will plug into your aftermarket headunit.
I've got a better question. On the site where they sell this adapter, how do you get the price? or better yet, how do you buy the d*mn thing!?!
Old Jul 19, 2007 | 09:55 AM
byc_panty's Avatar
lol for real..i was looking at the link and there was no way to buy it...
anotehr question....if i buy this adaptor does it mean i wont need to buy a separate harness connector???
Old Jul 19, 2007 | 09:59 AM
no, the harness connector is to supply power to the headunit. you will still need to buy that adapter.
Old Jul 19, 2007 | 10:31 AM
byc_panty's Avatar
ok ...i am searching vigorously as we speak right now...
it looks like the MITAH connector is the answer to this problem...
i think tehre are a few more out there...
cant wait to get my hands on one!!! i wanna blast some quality trance tunes while i drive my gokart
Old Jul 19, 2007 | 06:47 PM
byc_panty's Avatar
can someone confirm if both MITAH harness and MITSRCVR harness works with the Sun and Sound package system?
\thanks
