Problem w/Alram
Old Mar 25, 2010 | 07:54 AM
Ralliartize It's Avatar
Problem w/Alram
I had a new alarm system installed. The factory alarm was ghey and malfunctioned quite a bit. Anywho I drive my car last night and I realize my dash lights don't work. Any ideas of what that could be? I got it installed at a shop and I am taking it back today, so I'm just looking for preliminary ideas so the guy doesn't gut all my wires.
Old Apr 22, 2010 | 07:04 PM
majestic*'s Avatar
Sounds like the parking light fuse, domelight fuse or something along those lines is blown. Every alarm I have installed has a fused parking light wire on the alarm.
I guess it all depends on how it was installed and if this person is certified and knows what they're doing.
You shouldn't have blown parking lights unless they are integrated incorrectly... some alarms have selectable parking light output (+ or -)... if your parking lights are negative on the car and you give them a positive... it will blow the fuse... or visa versa.
Hope this helps,
Nick
Old Apr 22, 2010 | 10:40 PM
Thomar's Avatar
hmm, factory alarm in the RA? I donno bout that... was it an option?
Old Apr 22, 2010 | 10:42 PM
TurboTim06's Avatar
Def. Check Fuses before you take it in
Old Apr 23, 2010 | 12:26 AM
Lancer517's Avatar
Check the TAIL LIGHT FUSE!
I know it sounds completely random, but let me tell you a little story.
When I first got my lancer, before I became knowledgeable about car audio, I tried to install my own system, and I shocked myself by not grounding properly. Long story short, my dash lights, driver side tail light, passenger side headlight and high beam, and speakers stopped working. Turned out to be the TAIL LIGHT FUSE, replaced everything is working 100%. I never did get the SRS light to turn off though =[. Maybe its a different fuse in this case, but I guess my main point is to check all fuses, not just the ones you think it might be.
pinoyevo23
Sep 17, 2013 08:53 AM
boostx
May 9, 2011 05:33 PM
Spish
15
Nov 14, 2009 06:44 PM
rEVOlution517
Aug 20, 2009 03:38 PM
CasperGSR99
23
May 27, 2007 11:20 PM
