04-05 Ralliart ECU Pinouts
Here is a list, originally compiled by Myszkewicz, with the ECU pinouts for the 04-05 Ralliarts. The list is not yet complete, but it's mostly there, and will be added to at a later time. If there is something specific that you need, or you feel that something is incorrect, please send a PM to Otter.
TERMINAL NO. ITEM
1 Orange - No.1 injector
3 Blue/yellow - EGR valve (stepper motor coil <A1>)
5 White/red - No.2 injector
7 Malfunction indicator lamp (SERVICE ENGINE SOON or check engine lamp)
8 Fuel pump relay
10 Blue/red - Heated oxygen sensor heater (front)
11 Yellow/black - Evaporative emission ventilation solenoid
12 Yellow - EGR valve (stepper motor coil <A2>)
13 "CRUISE" indicator light input
14 Green - No.3 injector
15 Blue - Throttle actuator control motor relay
16 A/C compressor clutch relay
17 Blue/black - Fan control module
18 Blue/yellow - Heated oxygen sensor heater (rear)
19 White/blue - EGR valve (stepper motor coil <B1>)
21 Red - No.4 injector
23 Yellow/green - Evaporative emission purge solenoid
26 Green/orange - EGR valve (stepper motor coil <B2>)
27 Gray - Engine oil pressure switch
31 Black/yellow - Ignition coil - No. 1 (Ignition power transistor)
32 Black/green - Ignition coil - No. 2 (Ignition power transistor)
33 Ground
34 Red/yellow - Power supply
35 Red/black - Ignition coil - No. 3 (Ignition power transistor)
38 Accelerator pedal position switch
39 Green - Brake light switch
40 Clutch pedal position switch <M/T>
42 Ground
43 Red/yellow - Power supply
45 Blue/white - Generator G terminal
47 Red/white - Power steering pressure switch
50 Ignition switch-IG
51 Ignition switch-ST
52 Brown/green - Ignition coil - No. 4 (Ignition power transistor)
54 Blue - Cruise control cancel switch on brake pedal
57 Red - MFI relay (power supply)
58 Black/yellow - Backup power supply
63 White/red - Mass airflow sensor
69 A/C switch
70 Brown/green - Crankshaft position sensor
71 Blue/red - Camshaft position sensor
72 White/black - Fuel level sensor
74 Diagnostic output
78 A/C switch 2
79 Black/yellow - Vehicle speed sensor <M/T>
81 Light green/white - Fuel tank temperature sensor
82 Fuel tank differential pressure sensor
86 White - Generator FR terminal
87 Green/white - Tachometer signal
88 Black - Ground
89 White - Knock sensor
91 Brown/white - Ground
92 Blue/white - Power supply voltage applied to accelerator pedal position sensor (main)
94 Cruise control switch power supply
95 Pink/black - Engine oil control valve
96 Black - Ground
97 Yellow/red - Sensor supplied voltage
98 Yellow/white - Engine coolant temperature sensor
99 Yellow/blue - Intake air temperature sensor
101 Light green/white - Manifold absolute pressure sensor
105 Black - Throttle position sensor ground
106 Red - Power supply voltage applied to throttle position sensor
107 Blue - Accelerator pedal position sensor (sub)
108 White - Heated oxygen sensor (front)
113 Green - Throttle position sensor (sub)
114 Gray - Accelerator pedal position sensor (main)
115 White - Throttle position sensor (main)
116 White - Heated oxygen sensor (rear)
132 Red/white - Power supply voltage applied to throttle actuator control motor
133 Blue/red - Throttle actuator control motor (+)
141 Blue/yellow - Throttle actuator control motor (-)
TERMINAL NO. ITEM
8 Fuel pump relay
33 Ground
42 Ground
69 A/C switch
78 A/C switch 2
88 Black - Ground
96 Black - Ground
tboboy
Aug 7, 2010 03:39 PM
ApexSilver06MR
14
Dec 21, 2009 08:44 AM
benji
34
Jun 4, 2009 07:31 PM
