Fog lights in the headlights
Old Nov 17, 2004 | 12:11 PM
AznFlip's Avatar
worthless!
Show some pics to prove that you did it.
Old Nov 17, 2004 | 12:15 PM
.L.'s Avatar
.L.
Wha..... Wha..... Wha..... Wha..... What The? Where Are The Pics!?!?!?!?!?!
Old Nov 20, 2004 | 10:54 AM
rallylanceroz03's Avatar
here we go sorry on vacation
here are daytime pics as of rigth now will get soem night pics. installation is easy. go through the same procedure as you would if painting the housing black.
1. find a fog lamp set you like that will fit. (I found some i like and got lucky that they fit)
2. next take a dremel tool to cut into the back of the housing were the turn signal was so you cant mount it.(This part is hard takes a lot of patience to get it right).
3. after you get the mounting spots right go ahead and mount the fog light into the turn signal spot dont worry we move the turn signals else were ill get into that in a sec.
4.after that go ahead and use your best judgment on lining them up to make sure there level. its hit or miss. i got lucky and got it the first time.
5. after you are satisfied and everything is tightened down on the mounting hardware of the foglight its your choice to put the cover back. i didnt as it would kinda defeat the purpose of the fog lights i would think. it would spread the light out instead of a straight beam.
6. go ahead and reassemble the head light now. the same way you would as if you were painting the headlight houseing.
7. before putting your headlight housing back in the car here is were if you still want turn signals you can continune reading. if not just give me a few secs.. if you want your foglights to go on when your headlights do go ahead and cut the parking light socket off WARNING...... make sure you leave enough wire on the parking light socket you need this socket later on. so you have to wires. ( i think one is yellow the other black). you will use these and connect it to the fog light wires. (Yellow = +; black = -). if not go ahead and use the wiring harness you get with your foglights kit.
8. once you use the two parking light wires you now have your turnsignal with no were to go. go ahead and cut the turn signal socket off . now you have those 2 wires hanging around and your headlight bulb. if not your somewere else. go ahead and take your parking light houseing that you are supposed to keep extra wire on the end of. go ahead and connect your turn signal wires to the parking light socket. you now have your turn signals back in action and your all legal.
9.after you get all your wires connected and before you put the headlight all the way back in its up to you to use some kinda of grey or black high temp silicone and cover the back of the fog light to cover your big hole were the turn signal use to go thats if you have any light leaking.
10. go ahead put the head light back in and test everything make sure it all works. if it does congratualtions if not check your wiring or post again with questions.
also can i put my cell on here if anyone has any questions?
Attached Thumbnails Fog lights in the headlights-img00002.jpg   Fog lights in the headlights-img00003.jpg   Fog lights in the headlights-img00005.jpg   Fog lights in the headlights-img00009.jpg
Old Nov 20, 2004 | 11:20 AM
Sir Lancelot's Avatar
Are the fogs pointing down??? It kinda looks that way in the pics, but maybe its the angle of them..... Props for a new idea, but not that big of a difference in terms of lighting and looks. Maybe a hyperwhie silania bulb would look better???
Old Nov 20, 2004 | 11:35 AM
AznFlip's Avatar
Props to your own idea. Well try posting some night pics so we'll see how it look at night.
Old Nov 20, 2004 | 12:17 PM
drummerjun's Avatar
Looking good. Put yellow bulbs (~3000K) in them or the whole "fog light" idea is void.
Old Nov 20, 2004 | 12:28 PM
Pick_a_Fro's Avatar
Well they gotta be angled. Cuz fog lights are usually mounted low on the car, to light up the path for hence, fog...which lies low to the ground. Since the fog lights are in the headlights, with that height, it's gotta point down.
Unless u didn't intend that and u actually screwed up, lol...prolly not the case though.
Cool idea man, and great job !
Does it stay in there securely!?
Old Nov 20, 2004 | 12:52 PM
wingnut17's Avatar
Looking good, Get some good hyper white bulbs and you'll be set
Old Nov 20, 2004 | 02:37 PM
drummerjun's Avatar
what's up with you people and your rice hyperwhites?
Old Nov 21, 2004 | 12:45 PM
pgmike's Avatar
how is hyperwhite rice? now blue tinted stuff is another story. sylvania silverstars=brighter headlights=better visibility=safer driving, how is that rice?
Old Nov 21, 2004 | 12:51 PM
Mike@Accolade's Avatar
interesting mod.. i give you props for being original.
Old Nov 21, 2004 | 03:26 PM
drummerjun's Avatar
hyperwhites -> headlights = functional.
hyperwhites -> FOG lights = cosmetic
not sure why? go review your Physics.
Old Nov 21, 2004 | 03:54 PM
pgmike's Avatar
ok i thought you were talking about headlights too, chill
Old Nov 22, 2004 | 06:43 AM
AznFlip's Avatar
Rice topic again, can you guys stop saying rice, cuz rice is f***ing food!
Old Nov 22, 2004 | 01:42 PM
pgmike's Avatar
no
