Headlight Conversion
Old Dec 1, 2004 | 08:26 AM
akasirlancerlot's Avatar
hardly a mod even for someone who even knows what there doin i must say this would be a large waste of time.. of course if its pulled off great but even then u would have spent enough to turbo ur car. just get an intercoold rrm turbo???
Old Dec 1, 2004 | 11:33 AM
acs_guitars's Avatar
Originally Posted by twardOZRally
the big cost will come from new fenders, front bumper, and hood
If you know how to do real custom body work, meaning metal work... then you don't need a new hood or fenders. you could get the evo viii bumper, but it would be possible to avoid that with some trimming and fiberglass work. I am not talking about an easy 1 day job, it would take about a 3 days of tweaking the fit to make it look good.
Old Dec 1, 2004 | 11:36 AM
Originally Posted by nicktutt420
sounds like this is gonna suck.............................................. .as good as it would look, this is no mod for someone new to the modification scene
Good Observation! I agree though, get a turbo!!
Old Dec 1, 2004 | 11:46 AM
Evodreamer28's Avatar
Thanks guys. I think im going to reconsider. As far as the turbo im looking at that for late spring. Anyone got any ideas where I could get projector lenses for my stock headlights. I wanna do an hid conversion but I want to have the projector housing.
Old Dec 1, 2004 | 11:59 AM
drummerjun's Avatar
Originally Posted by Evodreamer28
in pa factory hids are legal because they are not nearly as bright as what I plan on buying. As well for them not to be illegal as pertaining to pa law I would need to have a projector housing inside my light.
I'm not a law student but...WRONG WRONG WRONG WRONG WRONG!
Factory HID's are the brightest > ANY aftermarket kits.
If you meant "brightest" by "the most colorful", then it's true. Factory HID's only use 4100k D1/D2 bulbs which is pure white (a bit yellowish before the color-shift) and no bluish tint whatsoever...
why? because 4100k is, in fact, the brightest, (same color temp as the sunlight, NOT thermal temp), hence provides the best illumination, and it's proven that only 4100k light outputs cause less/no fatigue, hence safer, and hence legal. (try stare at those blue/purple light beams for a while and see for yourself)
Also reason why aftermarket "blue/purple" HID's may SEEM brighter to you is because human eyes are more sensitive to blue lights. Try park a car with factory HID's and a car with aftermarket 6000k+ hid side by side, and see for yourself that the factory HID light beams will COMPLETELY overlap the 6000k+ lights.
As for the projectors + aftermarket HIDs = legal, again, couldn't be more wrong.
Again, factory HID's are legal because, other than the low standard 4100k bulbs, the housings (both reflectors and/or projectors) are designed specifically for the xenon D2S or D2R optics, so that the light beams will not blind any oncoming drivers. (D2R's -> reflector HIDs: IS300, G35Coupe, these bulbs are even more refined to reduce glare, thus may not be as bright as D2S, but still ownz joo)
aftermarket HID kits are ILLEGAL regardless which color temp (even 4100k) because our stock reflectors (or certain cars have halogen projectors) are NOT designed for xenon optics. No matter what kinda xenon bulbs you put in our housings (D2S,D1S,D2R, rebased, super high color temp such as 8000K~12000K), it'll cause severe bleeding above the cutoff line thus cause glare, blinding other drivers. Therefore, illegal.
If you think putting some projectors in there will eliminate this problem, buuuuuuuuuuzz, wrong. Most of the aftermarket projectors are poorly designed (choice/quality of lenses/reflectors/flip shield) as compared to factory-select projectors. They produce even worse light output than your stock reflectors. And shoving xenon capsules in there will not only hinder the true HID performance, but also causes tremendous glare/bleeding.
Old Dec 1, 2004 | 12:09 PM
DriftRunSir's Avatar
yeah but to save yourself the hassle of having to retouch the cracked fiberglass and bondo from the custom fit work, I would rather tell my customers to just do a full conversion rather than a half conversion especially on daily driver vehicles closing the hood with slight pressure in due time that fiberglass/bondo will crack and will require work+paint. Same goes with the pressure areas of a fender and front bumper where bolts are located. Thats why most cars with transformer style conversions end up becoming trailer queens...because it costs so much to have to rework all the custom bondo/fiberglass work from daily driving.
Old Dec 1, 2004 | 12:13 PM
God you guys are killing my hope here im not going to the conversion to the evo 8 lights cuz that sounds like hella work. Should I go with an hid conversion or do you think I would be better off without them?
Old Dec 1, 2004 | 12:17 PM
drummerjun's Avatar
^ easiet way is to get aftermarket kits which is illegal, but who cares. Just make sure you aim your lights lower so you wont blind other people, and so cops wont bug you.
Old Dec 1, 2004 | 12:20 PM
Thanks at least someone has given me a little hope into my adventure.
Old Dec 1, 2004 | 12:26 PM
dcorn's Avatar
How about converting your bank account to one with way more money so you can just buy an Evo. Then you can ask newb questions about a really nice, fast car with factory HID's
Old Dec 1, 2004 | 12:41 PM
lookslikeanevo's Avatar
wtf?...how about...n/m....
Old Dec 1, 2004 | 01:09 PM
Tweak3D's Avatar
I have stock head light housings on my car and will be getting my 4300k phillips hids and ballasts on friday. once I get them installed and aligned I will post a review and pics and then you can judge for yourself if that will make it any easier for you.
-Justin
Old Dec 1, 2004 | 01:11 PM
Why is that everyone seems to be downing my car and telling me I should get an evo. I dont want an evo sorry if I get flammed for this but im happy with just a regular lancer es and Im happy with what im doing to it. Instead of bashing people and telling them they are noobs why dont you just help them and give them advice instead of bashing them and making them not want the f***ing car
Old Dec 1, 2004 | 01:13 PM
Tweak3D's Avatar
its ok dude, some people just don't understand, just ignore them, I mean come on the guy telling you to buy an evo drives a civic, wtf is with that, you have no room to talk.
-Justin
Old Dec 1, 2004 | 01:18 PM
blacklancerr's Avatar
don't worry about it man. i have a good ole es too, and i love it. some people think they're better because they have a higher car payment, but just ignore them and do your thing! Theres nothing wrong with asking a question...its the best way to learn.
