need help with valve cover...
Old Dec 6, 2004 | 12:44 PM
akasirlancerlot's Avatar
ok so i just got done paintin it and reinstallin it... how tight are those bolts supposed to be, the ones that hold it on.. the rrm install guide just says no too tight, does this mena like tight enough u cant turn with fingers? or what i need help asap so plz help me!!!!
Old Dec 6, 2004 | 12:47 PM
tke_413's Avatar
just tighten then down and give them a little turn the screwdriver or whatever head it is...enought they won't spin back out, but not so tight that you crack it.
Old Dec 6, 2004 | 12:48 PM
azyan's Avatar
remember how tight they were when you take them off?
thats how tight it should be.
Old Dec 6, 2004 | 12:51 PM
Danno's Avatar
Simular to spark plug tight.
Old Dec 6, 2004 | 12:52 PM
lookslikeanevo's Avatar
2.5 ftllbs...not too tight cus then you will mess up the headasket...and not too loose where oil would leakout
Old Dec 6, 2004 | 12:56 PM
ItsTheDriver13's Avatar
From: Danville, CA (it really is all about nor cal)
1/2 turn past hand tight is the rule of thumb i believe.
and the head gasket is not the gasket under your valve covers. thats the valve gasket. head gasket is in the heads.......
ok so u mean not to tight like uhhh im gonna die if i puch it further? or like just enought to have it be kinda together..
Old Dec 6, 2004 | 12:57 PM
like i mean . right now they have some rersistance but i could very easily tighten more
Old Dec 6, 2004 | 12:58 PM
twardnw's Avatar
enough that it holds together, run the car around, then check to make sure it's not leaking. If you're worried about them holding, get some of the Blue Lok-Tite (not red, that kind takes heat to get it un-stuck)
Old Dec 6, 2004 | 01:00 PM
sorry i just woke up..the valve gasket it is
Old Dec 6, 2004 | 01:01 PM
dont run them around.....are you kidding? worst case he doesnt have em on tight enough at all and they vibrate right off...then the leak is a problem when your engine goes knock knock boom..... turn your engine on with ur hood open. have someone rev the car a little to get the oil back up in the covers. if u get smoke from oil DRIPPING on your exahsut manifold or anything else hot, you know you need to go tighter....but the 1/2 turn past hand tight is almsot fool proof. if you 2nd guess it - jsut go back after 50 miles and make sure one of them hasnt come loose. but generally 1/2 turn is fine.
Old Dec 6, 2004 | 01:02 PM
happens to the best of us. dont worry bout it lol
Old Dec 6, 2004 | 01:04 PM
twardnw's Avatar
well I would hope that he has it at least tight enough to not fall out right away, and also hope his engine is running well enough to be unable to vibrate a bolt out. if you can turn it by hand, it's too loose
Old Dec 6, 2004 | 01:07 PM
rev the engine in neutral. the engine vibrates plenty to have a bolt come off......
either way though.....too tight is better than too loose
as long as your gasket is silicone'd on to the cover you should be fine....the silicone forms its own gasket as well as makes the actual gasket stick.
Old Dec 6, 2004 | 03:07 PM
Lil red '03's Avatar
i got the RRM valve cover so i think the torque specs are like 13 - 15 in / lbs. I bought a craftsman inch / lb torque wrench from sears and it has really been worth it.
