CF trunk HELP!!
Old Mar 1, 2005 | 08:01 PM
03lancOZ's Avatar
oh it is quite lighter, very notice able... does anyone know if hood struts would work on the trunk?... dont see why not...
Old Mar 1, 2005 | 08:10 PM
Hotshot940's Avatar
where in ohio are you located?
Old Mar 2, 2005 | 09:11 AM
brentg07's Avatar
im in cincinnati, Im tryin to keep it lookin clean so i dont really want to do the bungee cords, I was told to take one of the tension bars out, which worked. It slowed it down a lot but, the side that still had the tension bar connected seemed to be pulled up a little
Old Mar 2, 2005 | 09:12 AM
brentg07's Avatar
o yea forgot to say that its a lot lighter
Old Mar 2, 2005 | 11:12 AM
Titaztik's Avatar
You will NEED to take out both of the bars...If you leave just one in it will slowly pull that side up farther and farther. I had to do this last year when I got mine. The only thing is, is that there is nothing pulling the trunk down either so it just "sits" on the weather stripping on the inside of the trunk. Which in other terms means that it won't sit completely flush with the car but will be close. Hope that helps
Adam
Old Mar 2, 2005 | 11:18 AM
gabrielg's Avatar
I Had The Same Problem, I Took It To A Local Body Shop And They Lined It Up For Me Perfectly.
Old Mar 2, 2005 | 01:42 PM
FlyNavy's Avatar
I don't doubt I could get this thing to fit right, but am concerned about the spring bars. Anyone running just one bar or none with stock-like function?
Old Mar 2, 2005 | 05:18 PM
brentg07's Avatar
yea thats kinda what i figured, o well still looks sweet
Old Mar 2, 2005 | 05:23 PM
SubiEvolved's Avatar
i just added washers to myne. It closes fine. Doesnt like up perfect though and i still have the springs in.
ERIK
Old Mar 2, 2005 | 05:29 PM
BillAce's Avatar
I just got my car back from the body shop. The stock trunk fit perfect but the VIS was off. When the seams on the top and by hte taillights were perfect, the trunk wouldn't close because the bottom bowed in. In addition to washers on the latch, they pulled the rear deck and adjusted the hinges outward from there. It fits pretty good now and doesn't leak.
Old Mar 2, 2005 | 06:39 PM
imajinmyfx's Avatar
nothing fits better than stock
CjParsons19
Lancer Troubleshooting
Apr 14, 2014 08:23 PM
gkew
Aug 1, 2013 11:08 PM
NateDaJew
Evo X How Tos / Installations
Dec 15, 2010 11:10 AM
foam
Nov 6, 2009 07:19 AM
MitsuJDM
Aug 9, 2005 05:05 PM
