Headlamp circumference
Old Apr 22, 2005 | 05:22 PM
HobieKopek's Avatar
For those of you who have opened your headlamp housing or just happen to know for any other reason...what is the circumference of the turn signal portion of the housing?
I'm debating doing custom angel eyes, but I'd like to do my rings before I open the lamps. I'm trying to avoid any other possible delays for the completion of my car, as it's been quite long enough already.
Old Apr 24, 2005 | 03:00 PM
pgmike's Avatar
i dont know, but cencoastlancer(sp?) should. he was the one making halos a little bit ago.
Old Apr 24, 2005 | 03:54 PM
FlLancer's Avatar
maybe ask modelchris since if i'm not mistaken he already has some headlights taken apart?
Old Apr 24, 2005 | 03:59 PM
Kelmar's Avatar
Hobie - If you don't mind waiting a few days, I'm going to be helping someone black out their headlights probably this weekend. I'll get the measurements for you then if you want.
Old Apr 25, 2005 | 02:58 PM
Blue04ES's Avatar
^ I got an 04 but yeah my headlights will be cracked open this friday hopefully
Old Apr 25, 2005 | 06:36 PM
modelchris's Avatar
ive opened up my headlamps and some civic projector headlamps. the angle eyes are DAMNNNN near a perfect fitment as far as the circle goes on the blinker. I dont honestly know the actual measurements, but i think just about any halo ring will fit there.
Old Apr 26, 2005 | 05:11 AM
Al Banks Holla's Avatar
I'm not sure about the circumference(sorry), but I'd say it has about a 4inch diameter.
Old Apr 27, 2005 | 03:36 PM
acs_guitars's Avatar
And the answer is......
The diameter is 3.5625 inches (or 9.04875 cm (or 3 9/16")) meaning that the circumference is 9.9678 inches (or 25.31823 cm). The diameter should be what you need. This is to the inside edge of the round part in the housing, the outside diameter of the clear lens.
Old Apr 29, 2005 | 06:31 AM
What's that old school formula? C=3.14xR(2)
Old Apr 29, 2005 | 06:41 AM
Kelmar's Avatar
Dang, I was probably going to have the answer today *shakes fist*
j/k Actually, I'll double check it just so he can have two answers to confirm it; that is, I'll check it if Blue04ES isn't too wasted....
Old Apr 29, 2005 | 02:58 PM
hee hee ^^ And yes.... C = pie are squared <----- I know it is spelled wrong
Old Apr 29, 2005 | 05:55 PM
sadude's Avatar
well since the other guy has had some problem with DIY angel eyes...maybe we should look into using the prefabbed ones that are available for the BMW and the like
check out
www.bimmerfreak.com
www.hidtech.com
Old May 1, 2005 | 09:29 PM
arnold16890's Avatar
isnt "pie R square" the area of a circle?
Old May 2, 2005 | 01:48 PM
Yeah, the Circumference equals pie(3.14) x R-squared
Old May 2, 2005 | 01:54 PM
TeamFlare's Avatar
Al you are right, but where is my ECLC decal
