My new interior
Old May 6, 2005 | 02:03 PM
TeamAccolade's Avatar
im glad the red chamelion paint worked out.. that was a b!tch to paint...
camaro379ss's Avatar
yeah i know the sun sux @$$!
Old May 7, 2005 | 05:52 PM
Short How to.
Tools Needed:
Socket Wrench, 17mm and 10mm ( deep socket or extention for 10mm.)
phillips screw driver
muscle
flat head screw driver
dash: first start but using a phillips screw driver to remove gauge cluster surround. Held in by 2 screws.
next pull off the 3 knobs. ( hvac controls ) this will reveal 2 screws, use phillips to remove them. then pull of hvac piece, this will reveal 2 screws holding clock unit and dash piece. clips finally old in the dash, remove by pulling. there are 2 harnesses that will need removed from clock, then its held on by a clip and 8 - 10 screws.
the little dash piece to the left ( power mirror area ) pulls out the same way, just push the mirror thingy loose.
to remove gauge bazel, take off clear plastic, built in tabs, then remove black bazels, built in tabs and then its ready for paint.
A pillers and C pillers pull off nicely, just pull and they should unclip.
B pillers, requires removal of door sills, seat belt and black piece door sills go into to. first remove door sills. then pull loose the black pice. then pull of front of seat belt, next use 17mm socket to take off seat belt. the b piller should pull off at the top and the slide up.
lights ( 2003's with sun roof ). take a flat head screw driver to remove clear piece. then use 10 mm socket to remove.
sun roof switch, pries off.
door handle backing, there is a square piece, pop it off and there is a screw, remove it and free the piece.
door grab area, this piece has a square piece in the bottom, use a phillps to remoce.
Window accents - to remove pull up then release wire harness and unscrew.
top piece of center dash, to remove go to drivers side and knock off the panel by the gas. then pull on the top of the cener piece. ( car will need to be in N and have P-break set. ) you will need to remove a light and the cig lighter.
any question IM or e-mail me!
Old May 10, 2005 | 08:36 PM
pgmike's Avatar
dah too much red! id paint it black ro silver.
Old May 11, 2005 | 02:19 PM
03chi-town0Z's Avatar
ok, well, no use posting what my interior looks like, just look at camaro's and you'll see mine...except the pillars on mine are black and the headliner is red...damn you camaro. why didnt you bring it to the airport?
Old May 11, 2005 | 03:00 PM
futurevo's Avatar
how much prep was involved???
Old May 12, 2005 | 01:19 PM
doesnt take much, just take the pieces off and clean em up real good with a good solvent, i used 3m bug and oil remover, to get the armorall or whatever was on there off. then you probably are gonna want to sand down the pieces to smoothness, but if not, at least scuff them up with some like 800-1000 grit sandpaper so the primer sticks well. then paint carefully otherwise you get mad orange peel effect. clearcoat and wait 12 hrs to dry. then wax and replace. waxing isnt necessary but it shines that much more and adds another layer of protection. armorall works fine anytime you wanna clean it up afterwords
Old May 12, 2005 | 01:22 PM
EvoVIII_MR2005's Avatar
Im not gonna rip on it but im not going to overly compliment it....Nice paint job, but im not into the whole interior painting thing. Your car though, so if you like it, who the **** cares what i think.
Old May 12, 2005 | 02:18 PM
only prep i did was scuffing, and i couldnt bring it to the airport b/c i had too much **** packed and kevin needed a way to get his stuff from his house to the airport.
Old May 12, 2005 | 02:19 PM
I dont want my interior all black b/c then i'd feel like i'm gothic!
pharcydeabc
Apr 17, 2017 12:17 PM
Kracka
North Texas Evo Club (NTEC)
55
Nov 9, 2010 08:06 PM
ggogl
Apr 22, 2008 10:21 AM
LancerOZ Boy
Aug 22, 2006 12:42 PM
Rod Munch
14
Jul 27, 2006 07:38 PM
