RRM evo 7 wing wobble troubles
Old Sep 19, 2005 | 01:15 PM
redozrally's Avatar
you can get a piece of metal and put it underneath the wing to reinforce it... stick some double sided tape and screw that **** on the wing...
I've heard some ppl do that 2 their aftermarket evo8 replica wings...
metal as in something thin and durable that will span the lenght of the wing...
Old Sep 19, 2005 | 01:31 PM
mitsuozboi's Avatar
its not even that its loosening, its all tight and looks good, flush with trunk even. It is the cross section the "shakes" OR "bounces up and down" when I get anywhere near 40 or above. it vibrates some over bumps but that doesnt bother me. i got an adjustable one and tried changing angle of cross section but it didnt do anything. Ill probably return it, calling rrm today and get a cf one. I figure cf wont do it since its more rigid.....or oem i guess, where can i get that. does rrm sell them?
Old Sep 19, 2005 | 04:10 PM
mitsuozboi's Avatar
thanks for info, I called rrm (they are a big help), ill try the rubber washer bit and foam tape on base. should fix problem.
Old Sep 14, 2006 | 08:17 PM
fastevo03's Avatar
I have a Evo 7 (in Asia)and it wobble at starting 50-60mph. Typical problem, that's why evo 8 is redesigned and it's CF
Old Sep 15, 2006 | 12:22 PM
SLVROZ_03's Avatar
I think you got your answer. But I've had my OEM Evo VIII CF wing for a couple years now and have never seen a wobble. Even @ 120...
Old Sep 15, 2006 | 12:38 PM
DemisedGabe's Avatar
mine wobbles, but not that bad
Old Sep 15, 2006 | 06:28 PM
Achilles's Avatar
Try a vortex generator, that might help.
Old Sep 15, 2006 | 11:35 PM
IceXpert's Avatar
hmm, ok, pretty sure that would do absolutely nothing.
i have the replica evo 8 wing also from rrm and my center section also wobbles like crazy over bumps, windy weather, or speeds over 40. accolade says their wing is made of different material and wont wobble (additionally, its far cheaper then an oem or cf one). u could go that route, especially if your gonna return the rrm one. i havent done it cause im not sure i want to risk buying another, painting, blah blah. whatever route you go be sure to let us know what works best, accolade, foam inject, metal support. the rubber washers and extra tightening will not work. i can almost guarantee you that. the problem is that the force the wind puts on the center of the cheap material is too strong for it to not flex. the support on the ends can be superior, but because the wing is so long, in the middle there is no support other then the abs.
Old Sep 17, 2006 | 02:30 PM
mitsuozboi's Avatar
I since sold the wing. The guy who bought it hasnt mentioned anything about it. Adding the foam washers and such did help. I was gonna install it but ended up going cf trunk/wing route.
Old Sep 17, 2006 | 02:57 PM
atilla's Avatar
it actually does wobble.
not enough to bother me though. i tend to watch the road in front of me more than behind me when i drive.
Old Sep 17, 2006 | 06:48 PM
Walkingchaos's Avatar
maybe i missed the post gut has anyone mentioned using a gurney flap to keep it from wobbling ? those work and are alot easier to find use and keep on there.
Old Sep 18, 2006 | 04:50 PM
mitsuozboi's Avatar
Yeah. I saw the gurney flap recently. Would they be rigid enouph to help though?
Old Sep 18, 2006 | 07:04 PM
LancerOZ Boy's Avatar
I have the accolade evo 8 and it wobbles a little bit but not much. I only have 1 screw on each side though..im thinking about putting anothe one in and see if it stops
Old Sep 18, 2006 | 07:19 PM
02-Lancer-Es's Avatar
i got my evo 9 oem spoiler (same as evo 8) for only 100 with shipping, it does great , going like 100mph and no vibrations what so ever, there was one last night on ebay, but i think it finished this morning, also oem from a evo 8, oh and mine has 2 screws and 2 bolts
Fasturbo
Feb 4, 2017 08:46 AM
poonpower
Oct 22, 2016 06:35 PM
Blue Evo 8
18
Jan 10, 2009 02:33 PM
el producto
20
Apr 18, 2006 06:47 PM
StreetSleeper8
14
Nov 30, 2005 10:13 AM
