Help with hood
Old Mar 10, 2003 | 09:14 AM
jtlake's Avatar
Help with hood
Has anyone put on an aftermarket hood by themselves, or even a OEM hood? Is it difficult. Some pointers would be nice. Thanks
Old Mar 10, 2003 | 09:16 AM
Crzylizard's Avatar
Its not that hard...
I havent put one on my lancer...but had to put one on my mustang after i had wrecked it.
Shouldnt really be hard...just get someone to help you and dont tighten the bolts all the way down till youre sure yuo have it lined up straight
Old Mar 10, 2003 | 09:34 AM
03YellowOZ's Avatar
Its pretty easy that was the easiest part of my kit it just bolted right up unlike all the othere peices.
Old Mar 10, 2003 | 09:38 AM
LaNceRiTiZ's Avatar
......only four screws holds the hood...
...very easy.....
Old Mar 10, 2003 | 10:03 AM
purecoda's Avatar
I heard that if you go with a lightweight aftermarket hood, you need hood-pins to hold it down (for saftey). Is that true?
Old Mar 10, 2003 | 10:05 AM
MrSpace's Avatar
it's easy, but not that easy!
I changed mine on my integra also when I crashed the front end.
Alone it will be hard, with someone to help it's not bad, one to align everything (make sure the gap on each side is ok) then you tighten a little, check bak alignment, tighten a little more.
And as for wheels you tighten all bolts at the "same" time not one byt one.
Etienne
Old Mar 10, 2003 | 10:11 AM
HobieKopek's Avatar
From the accounts I've read it's a good idea. The latch alone may be enough to keep the hood from flying up, but according to a couple accounts I've read it will begin to flap and make noise at high speeds especially. If nothing else it's about 20 bucks for some piece of mind and to avoid an annoying noise.
Old Mar 10, 2003 | 10:19 AM
Crzylizard's Avatar
Yes, hood pins are the greates thing since sliced bread
First hand experience:... spend 350 on fiber hood with no pins... hit 100 on the bypass...hood breaks in half across top of windsheild (convertible).....spend 350 on fiber hood AGAIN, buy hood pins this time...much better result
Old Mar 10, 2003 | 10:26 AM
03YellowOZ's Avatar
If you go with hood pins keep in mind that if dont do the locking kind then people can get under your hood in under 5 seconds all the need to do is flip the latchs up. To me that wasnt really a problem I dont live in a bad area but it could work against you.
Old Mar 12, 2003 | 01:56 PM
DMBcrew36's Avatar
Where could one find a light hood with an air scoop on it? Almost like the on in the apex kit.
Old Mar 12, 2003 | 02:00 PM
BOOYAH1369's Avatar
In Timeout
calwich?
Old Mar 12, 2003 | 02:01 PM
uranium9v's Avatar
If you go lightwieght or CF you'll need the pins...keep your stock latch though for security reasons. If your looking for a hood, all there is now are the CF hoods and the ones from Bodykit.com. I'm thinking about modifying my cf hood, but haven't had the ***** to yet...
ant_turbo
Jul 20, 2016 06:06 PM
rong.
Jun 20, 2016 06:23 AM
EvolutionIXMR06
For Sale - Part Outs
May 4, 2016 01:59 AM
silkey00
Nov 5, 2015 09:37 AM
truthdweller
Northeast Region
Jul 6, 2012 08:27 AM
