Oz Gauges Vs. ES Gauges
I know this has been answered a million times but would just like to clear it up. im in the process of purchasing a OZ version of the gauge instrument cluster from a salvaged car.
Is this a direct connect?
Does it matter that i have AT?
Also it shows that it has cruise control but i don't have that in my car will that matter when hooking it up?
And also one more question, when changing the miles on the new one, has anybody had any problems with the dealer or not?
My car has 29000 miles on it and the guy that im buying it from says that this one only has 31000 on it. Do you think that i should not even care since they are so close to each other.
Any input you be most apriciated
And also one more question, when changing the miles on the new one, has anybody had any problems with the dealer or not?My car has 29000 miles on it and the guy that im buying it from says that this one only has 31000 on it. Do you think that i should not even care since they are so close to each other.
Direct plug in. Unplug the ES and the OZ/RA/Evo plug in the exact same way.
No it does not matter
It's extremely easy to do yourself, but if you're worried about the milage difference the dealership told me I should have taken it to them to install so they could note the odometer reading. But that's only if you feel like giving them more money on something you could do yourself.
I ended up sending both my ES and the OZ cluster to a company( http://www.specmo.com/) so they could calibrate it. Did not go through the dealership. I'm not sure how to do it yourself.
Just curious, what are your plans for your ES gauge cluster?
Like mentioned above, everything is direct plug and play. You can't chang the odometer yourself without about $1000 of software and harware. Better to have it sent to a company if you're worried. I like the drive around for another 2000 miles first then switch it out
i have no plans for the ES cluster, If everything goes well i will have no use for it. Are you interested in buying it?
By the time that i get the cluster sent to me in the mail ill have racked up 2000 more miles on my car since i drive alot, so im not worried to get it professionally changed unless there are other problems that resort from that.
i think they are in both the same spot. I had that question to since i might have to change the glass piece from the oz one to the es one since from looking at the pictures it might be scratched up, but i wont know for sure until i recieve the OZ cluster.
Originally Posted by XAlliedYouthX
What I've been wondering about is if the button you push to reset the mileage lines up the same on both clusters?
