Another body kit question
Old Apr 24, 2006 | 07:41 PM
04ozrally's Avatar
I have been hearing the fiber glass kits don't really hold up well over time and that urethane is the only way to go. Can anyone offer any advice as to whether this is true or not and is their even a urethane kit for the lancer? All I have seen is carbon fiber and fiber glass.
Old Apr 24, 2006 | 07:44 PM
04lancerEsGuy's Avatar
Urethane
parts are made of reaction injection molded polyurethane, a material that is lightweight, flexible and resistant to rough weather conditions and everyday road hazards. Because of its flexibility and light weight, parts made out of urethane are usually easier to install. Wings West is an example of a company that manufactures a body kits using high quality urethane. There are several other companies as well, all are very 'reputable' in brand name.
Fiberglass
is a material well-known for its resistance and rigidity. It is crucial to choose the highest quality fiberglass for your body kit. Many companies create bad quality parts containing wavy patterns on the fiberglass and unsatisfactory fit. Fiberglass components that are hand laid have no waves and are not brittle or weak. When a part is hand laid, the part will be uniform and will have an even amount of fiberglass throughout the component. Hand laid fiberglass takes the longest, and costs the most but are worth it. Unfortunately I have YET to find out any companies that make good quality fiberglass kits for the focus, and yes this includes JTAutostyle kits which have been 'rumored' to be a decent fiberglass kit. To this day, I don't know of ANY companies that offer high quality hand laid fiberglass kits for the focus, nothing common in North America anyway.
The biggest issues, more common, are below......
Urethane kits are FLEXIBLE so any slight impacts or bumps will not crack the kit.
Urethane kits are RESILIENT to weather so hot or cold, they can withstand the climate (rain, hail, snow).
Urethane kits are EASIER to install since they have some flex to contour to the body parts.
Urethane kits are EASIER to prep before the painting process thus costing you less at the bodyshop.
Fiberglass kits are NOT FLEXIBLE so the slightest bump and she's cracked.
Fiberglass kits are NOT RESILIENT to weather so they can get even damaged even easier due to this.
Fiberglass kits are HARDER to install cause they almost always require cutting, sanding down, etc to actually get the part to fit properly.
Fiberglass kits are MORE EXPENSIVE to prep and paint, due to the needed shop time to get the kit to fit properly.
What it comes down to in the end is you can 'usually' get a high quality URETHANE kit purchased, prepped, painted and installed for LESS then the cost of a fiberglass kit.
Another thing to keep in mind, NO brand name body kit company out there (commonly) uses fiberglass to construct their kits. That should say something if you haven't gotten the point already.
URETHANE > FIBERGLASS
Source: http://www.focusfanatics.com/forum/s...threadid=57197
Old Apr 24, 2006 | 07:46 PM
There are very few famous companies that make body kits using urethene but the problem is they dont make kits for the lancers.
