Horn connected to high beams
Old Apr 23, 2003 | 10:28 PM
Kralster's Avatar
Lightbulb Horn connected to high beams
Anyone know if it is possible to connect the horn to the high beams. I am wanting my high beams to go on when i press the horn and then off when i'm not hitting the horn. If any of you have played Need for Speed: hot pursuit II you know what i'm talking about. Just wondering any info would be great couldn't find any info through the search feature.
Old Apr 23, 2003 | 10:44 PM
Smoktout's Avatar
that's a cool idea even tho i'd have no clue how to set it up.
sorry, maybe someone else can help, possibly in the audio and security forum.
Old Apr 24, 2003 | 02:09 AM
Dr Crash's Avatar
you could do it with a couple of relays. use the negative horn wire voming through your steering column as the trigger for the relays and send 12V to your high beam wire. should be pretty simple. when i tear apart my lower dash to install my 2-way pager alarm i will try to find out the colours for you, but that won't be for a week or two, cuz i still have 2 exams left
Old Apr 24, 2003 | 08:06 PM
FaLLeNAn9eL's Avatar
ask the cops..im sure thier sirens and the lights are wired the same way
Old Apr 25, 2003 | 02:35 PM
Hellacious's Avatar
That'd be sweet....I'm sure a shop could do it
Old Apr 25, 2003 | 02:52 PM
zyounker's Avatar
split the wire going to the horn in the front of the car, and hook it to a 12v relay 30Amp would probably do..
Then the output of the realy would go to the high beam wire on the lights.. not sure wich wire as i dont have a lancer. should be easy to find with a friend and a volt meter though.
-Zach
Old Apr 28, 2003 | 04:18 PM
mikenuts86's Avatar
hahahaha...that would be a great mod, good luck
Old Apr 28, 2003 | 04:25 PM
mark2002lancer's Avatar
Old Apr 28, 2003 | 05:15 PM
Thwack's Avatar
just splice the horn and high beam wires under the steering column, both before their respective relays. you might want to include a diode of some kind onnthe horn side, otherwise when you tunr on your high beams it would honk the horn continously as long as your high beams are on..
on 2nd thought, screw the diode, i think that would be pretty damn amusing...
"hmm its dark here, lemme turn on the brights... (click) HOOOOOOOOOOOOOONNNNNKKKKKKKKK!!!!!
Old Apr 28, 2003 | 06:00 PM
Bitnode's Avatar
hahahaah that would be so funny!
Old Apr 28, 2003 | 06:02 PM
psmokie68's Avatar
lmao lmao
Old Apr 30, 2003 | 10:09 PM
tyger's Avatar
Hate to be the bearer of bad news...but that might be illegal.
