headlight mods
Old May 19, 2003 | 11:54 PM
trance's Avatar
headlight mods
iknow of some who have done the mod to change the side driving lights(wich stay on when the lights are on)and the round blinkers so that the blinkers stay on and the sides blink...now i know the process to do this but am woundering if anyone has had any problem due to the wattage change?
i know uranium9v has done this and so far all he has noticed is that the blinkers blink faster than normal.
i am more conserned about the watt change messing up the wires or the harness...anyone else thought about this and have a idea?
Old May 20, 2003 | 02:15 AM
Chicago Lancer's Avatar
I've been wanting to get my sidemarker lights to stay on too. I wouldnt mind having the corner lights blinking instead either. I also want them to blink faster I think it looks way better . Any advice on how to do this?
Old May 20, 2003 | 02:30 AM
BlackLancer2k2's Avatar
to make your lights blink faster...just replace any set bulbs...front or back...with LED's...they draw less wattage and will make the lights blink faster..they do on mine..i have LED's in every single bulb possible..except for headlight
Old May 20, 2003 | 08:06 PM
trance's Avatar
I'm more wanting to onow about the wattage change and how it may affect the wires or harness??it's no biggie if my blinkers are faster or what not...i just don't want to have to explain to Mitsubishi why the wires or harness got melted
Old May 31, 2003 | 10:51 PM
2002OZ's Avatar
Help
I have searched and searched for this topic, i am also wondering what the process is to do this, I want to make my headlings like the lexus IS 300 is this going to mess up the wireing or anything bad? Let me know.
2002OZ's Avatar
Help
Old Jun 15, 2003 | 05:23 PM
2002OZ's Avatar
still need help
Still need help with this!!! can anyone give advise
Old Jun 15, 2003 | 05:36 PM
FaLLeNAn9eL's Avatar
The smilie says it all
Old Jun 15, 2003 | 05:57 PM
2002OZ's Avatar
I could try drawing a diagram
Old Jun 15, 2003 | 06:00 PM
Iamkar33m's Avatar
I did this so called blinker and parking light switch...
Now my parking lights are the lil circles inside of the headlights and my blinkers are the corner lights. It looks ALOT like the IS 300. All I did was splice the 2 wires and flip em. Also that got the blinker to blink faster cuz the small bulbs in the corner draws less voltage
Old Jun 15, 2003 | 06:05 PM
2002OZ's Avatar
Thanks
So all you did was cut the wires black to black and green to I think its blue and just connect them together.
Old Jun 15, 2003 | 06:54 PM
trance's Avatar
now my question still holds...
Will the wattage/voltage change from the change have any effect on the wireing or harnesses?
i know from past experience that wrong wattage with the wrong wires or bulbs can burn through the wires and even fry the harness.so far i know a few who have done this and so far no prob but it has only been a few months ...i guess i just dont want to harm my baby
Old Jun 15, 2003 | 07:21 PM
4Gaijin63's Avatar
there is no wattage/voltage change. you're simply switching which bulbs recieve the power. the harness has no chance of being damaged unless you're an idiot and mess it up whilst splicing the wires.
EDIT: on second thought, the bulbs might get damaged but i dont think thats possible.
Old Jun 15, 2003 | 07:53 PM
neilschelly's Avatar
Some misinformation being posted, so I'll kick in what I know. The wires going to the side lights and the wiring going to the blinkers are the same gauge (at least visually, so probably). The wattage will change, because the lights do have different resistances. The voltage going across them in both cases is 12V, but the lower resistance one will allow more current through and so a higher wattage (current * voltage).
The important lesson here though is that the side light will still run the same wattage before and after this mod and the blinker light will still run the same wattage before and after this mod. The wiring used for each is the same size, so no worries there and the fuses are probably 10A for all of them (probably all on the same fuse anyway).
So there's really nothing that the change in wattage can hurt or even affect...
-N
Old Jun 16, 2003 | 04:32 AM
kbadboy's Avatar
their really shouldnt be......
