Newfoundlancer's Build-up Thread
I've only had a chance to spin the rims when the car was up on jackstands and the suspension was decompressed. The only rub that I managed to get from them was at full-locked-right turn which only left about a 1inch square rub in the dirt on the inner wheel well wall. In order to fully test it, it will probably have to wait until I get the car out in the spring. I have moved the car around in the garage a little since putting her back down on the ground and have turned the wheels fully left and right while doing so, and there was absolutely no rub then. Overall, I think any rubbing will be to a minimum for sure, so don't be afraid of getting rims. I got 42mm offset rims, so if you want to be really safe, go with a 40 or 38 offset. I'll be looking forward to seeing a new set of rims on your thread in the near future
Good luck!
Good luck!
Good luck!
Good luck!
My g/f took a few pics while we were out driving in the snow storm currently hitting Newfoundland. How it relates to this build-up thread is that I'm not out beating up the lancer or putting more snow-brush swirl marks in the paint
And a couple from my window:
Finally... it's amazing how the flash of a camera can magically make a storm appear!
naw! i only put mine in the ditch like 10 times. ha jk it was just once and i figured i probably should stay off unplowed dirt roads. back on topic though. really nice lancer, i like all your progress. it would be so nice to have a garage like that but im stuck with the one car garage at our apartment complex, but size doesnt matter, its how you use it. lol. when it warms up i think i MIGHT actually start one of these build up treads if i have enough projects. anyways keep up the good work and keep us posted.
Thanks... as of right now, I have the following items on the way:
-RRM Front Strut Tower Bar
-RRM Rear Strut Tower Bar
-RRM Lower Tie Bar
-RRM Sway Bar w/ Perches
-Evo 8 Spoiler
-Drilled/Slotted Rotors
I'll get updates and pics posted once they arrive and I get to the garage for the installs... but now you guys know what the next few updates have in store!
As well, Newfoundland is due for a blizzard tonight, so you never know... I might wander off-topic again to show off my little 4x4 winter beater vehicle some more
-RRM Lower Tie Bar
-Evo 8 Spoiler
hey, if you were still interested in doing your rear mount, you can buy them here for much less than you thought: https://www.mitsubishiparts.com/oe_parts_catalog.html search in the collision catalog under 2002 in engine/transaxle and you should find it for around $38.00. or you can buy my extra one from me for even less, lol!
