Turbo?????????
Old Jun 18, 2007 | 09:54 PM
MaD_CaNaBiCe's Avatar
Turbo?????????
Hey guys I am planning on boosting my 02 es with no mods just wondering what you guys think of this kit as far as reliability and safety.I am also plannig to run 7 psi at the most.Also for those who are gonna mention rrm kit i don't feel like spending 4k for their kit and I know it's the best but I just want something to have a lil fun with but reliable and safe.
http://cgi.ebay.com/ebaymotors/02-06...QQcmdZViewItem
much thanks in advance
Old Jun 18, 2007 | 10:10 PM
WangMan's Avatar
The most common response will be: you get what you pay for... but I don't know a thing about turbos so I'll let someone else critique this product
Old Jun 18, 2007 | 10:21 PM
ambystom01's Avatar
You do indeed get what you pay for. Let me put it this way, I would not put that kit on my car nor would I accept it as a gift.
Old Jun 18, 2007 | 11:43 PM
dewood*'s Avatar
if you do it and it works i'll do it
Old Jun 19, 2007 | 12:09 AM
sly's Avatar
sly
id say save more get a better kit
Old Jun 19, 2007 | 12:39 AM
kungfugirl's Avatar
enjoy the bus
Old Jun 19, 2007 | 12:40 AM
stEVOx's Avatar
from the pics it looks good, it is using the same turbo i plan to, but it seems a lil cheap for all the parts u get,
buy it and then u can check the quality of them,
even if u need to replace the IC and IC piping coz there crap, u still have the rest of the kit which is cheap for 780 i spose
Old Jun 19, 2007 | 07:05 AM
AK805's Avatar
I suggest that you don't turbo your car without modding it... Leaving your car stock and putting a turbo is going to overheat/blow up your engine.
Old Jun 19, 2007 | 07:13 AM
SLVROZ_03's Avatar
If you hadn't noticed, this is an incomplete kit and is universal...not "just for" a Lancer! It'll get you started, but it's missing very key pieces; fuel mgmt, turbo mani, etc etc...
Old Jun 19, 2007 | 07:34 AM
crypto's Avatar
Former Vendor
its another standard incomplete, unreliable, untested Ebay kit.
don't waste your time with it.
Sorry to tell ya., but your not gonna get a turbo kit for under $1000
either buy a RRM kit for $4k'ish
or build a custom kit for around $2k, or find a used RRM kit, which will run between $1-3K
Old Jun 19, 2007 | 10:42 AM
lncrphish's Avatar
http://www.roadracemotorsports.com/turboparts.htm
RRM turbo mani and o2 housing $550.00
http://www.ssautochrome.com/level.itml/icOid/1291
NEW T3 TURBO, 38 MM WASTEGATE, and NEW IN THE BOX BLOW OFF VALVE
$250.00
Complete Oil Kit - T3 T4 $80.00
You can find a feul pump and stock evo ic on this forum for sale for around $100.00 each.
Do some custom piping and wa-la…
I have a turbo manifold for 4g94 fits t25 turbo if you want it pm me.
Hope this helps.
Total cost around $1200. but you don’t have to get it all at once. And its your own custom build.
Old Jun 19, 2007 | 11:25 AM
Chicas's Avatar
I've read around here(I think, not so sure what exactly I read) that the Lancer runs pretty good with 5psi, stock.
Old Jun 19, 2007 | 11:48 AM
ambystom01's Avatar
$250.00
Hope this helps.
For 250$ there is no way you'd get a real T3 turbo, it'd be a generic knock-off. Same goes for the wastegate and blow off valve. Hell a good blow off valve can cost 250$.
Old Jun 19, 2007 | 12:30 PM
jakermeister's Avatar
You got it. 5 psi for non-intercooled and 7psi for IC. If you go any higher you gotta upgrade your internals (pistons & rods).
I guess the only thing we can tell you is to go custom to get a lower price. It might take longer to get the parts but you'll make it.
Old Jun 19, 2007 | 01:11 PM
lncrphish's Avatar
ok, i will retract the turbo from ssautochrome.com after some research i found lots of negative comments on the quality and durability.
