water spots
Old Jun 26, 2003 | 11:42 AM
MaDLiB's Avatar
water spots
does anyone know how to take out rough water spots? i have some on my side view mirror and tried everything! any help is appreciated
Old Jun 26, 2003 | 11:49 AM
uranium9v's Avatar
Stoner makes Liquid Glass.....that stuff works!!!
Old Jun 26, 2003 | 12:07 PM
norefills's Avatar
use windex and a razor blade
psionic98's Avatar
if its on the glass part of the mirror try this stuff.. I got it at pep-boys I think, its called Strip It, made by Wiper Mates.. its like rubbing compound for glass. it worked for me with my old Bronco that had some scratches and stuff in the glass.
Old Jun 26, 2003 | 12:10 PM
Sir Lancelot's Avatar
NEVER USE A RAZOR BLADE ON PAINT!!!!!!!!!!!!!!!! I DONT CARE WHAT YOU ARE TRYIN TO GET OFF NEVER USE A RAZOR!!!!!!!!
What I do suggest you use is a little carb cleaner and some liquid glass to top it off!
Old Jun 26, 2003 | 12:14 PM
MaDLiB's Avatar
its on the mirror
Old Jun 26, 2003 | 12:16 PM
norefills's Avatar
thank you...
Old Jun 26, 2003 | 12:28 PM
psionic98's Avatar
if its on the glass, then the razor idea would work.. just takes some time sometimes cause of not wanting to scrape up the plastic around the mirror edge... we seriously need some replacement mirrors for the lancer, like the blue tint stuff..
Old Jun 26, 2003 | 12:42 PM
MaDLiB's Avatar
ok thanks guys
Old Jun 26, 2003 | 12:43 PM
MaDLiB's Avatar
so just a razorblade and windex?
Old Jun 26, 2003 | 07:34 PM
diesel_fan's Avatar
Before the razorblade, try and find some BonAmi cleanser in a grocery store - it's in gold can with a baby chick on it. Dampen a sponge, wet the mirror glass, sprinkle a little BonAmi on the sponge then wipe back and forth / up and down. With minimal elbow grease, the water stains/spots should be history.
BA is clay based with no silica or abrasives. GM has been selling it for years to clean windshield exteriors.
Old Jun 26, 2003 | 07:40 PM
pjal84's Avatar
I use the Goo Gone soap for small areas of spots. Not to much and voila, the spots are off. Need a longer hose to attach the water softener.
Old Jun 27, 2003 | 05:25 PM
suntzu's Avatar
for the glass ... i used ultra-fine steel wool and any quality powered waterspot remover - add a little water and wah-la ... good as new. takes a bit of elbow grease but you'll like the results. respect.
