Lancer paint issue with license plate
Old Jun 27, 2003 | 11:28 AM
VALancerOz's Avatar
Does anyone have an issue specifically with their license plate scratching the lower lip on the OZ version or even the other trims? If you guys do, please post a pic so I can show the Mitsubishi rep. when I see him next. All they want to do is give me a bottle of touch up paint and forget the issue. I need some tangible proof that it just isn't MY Lancer. I will keep you guys posted with what the guy says. And I will get a pic tonight of what I am talking about as soon as I get home. Thanks...
Doc...
Old Jun 27, 2003 | 11:41 AM
HobieKopek's Avatar
Yeah, I did. My lip's not on my car right now, but if I remember I'll post pics Sunday.
Old Jun 27, 2003 | 11:43 AM
Guru_Del's Avatar
actually i read a thread on this about 4 months ago and a few people had that problem
i_love_spool's Avatar
That happened to me....you know why it happens, because the dealer puts on their license plate holder which keeps the plate from being blown onto the lower lip and scratching it. When you remove the dealer plate holder it scratches the lower lip. I ended up putting on the AEM plate holder (much to my despise) so that the plate wouldn't **** up the lower lip anymore. I'll take a picture and send it to you.
Old Jun 27, 2003 | 11:58 AM
VALancerOz's Avatar
That one died out in May and they were talking about all issues with the paint "defect". This is scratches due to the license plate being mounted to low and it is pushed back, and rubs the lower lip on the OZ. I wonder what ever happened with that thread though, have to find it.
Old Jun 27, 2003 | 12:00 PM
zlancer's Avatar
okay well just drill holes in your license plate so you can raise it up 1/2 an inch. problem solved.
Old Jun 27, 2003 | 12:04 PM
magz's Avatar
Well, that happened to me also, but I found a remedy to the problem.
The screws have this large sphere rubber boot that the screws themselves screw into. Here is what you do:
Put on your license plate and screw in the screws. Keep screwing the heck out the the things. What happens is that the screws squeeze the rubber boots on the bumber and the more you squeeze it the less play the license plate will have. So, I used my drill to screw the heck out of it and it never happened again.
Oh also, I removed the scratches that it left by using Meguier's Body scratch and swerl remover. Looks the same as the moroon polish bottle. It removed the scratchs and made it back to normal. NOTE: If you use this scratch remover, make sure you wax the area a couple of times to prevent oxidation. This scratch remover is pretty strong but works GREAT! I highly recommend it.
magz
Old Jun 27, 2003 | 12:08 PM
riceburner221's Avatar
Registered User
it not just the oz it the es too
Old Jun 27, 2003 | 12:09 PM
magz's Avatar
Yeah... it should work on both OZ and ES!
Old Jun 27, 2003 | 12:14 PM
VALancerOz's Avatar
That's a good idea, but what I actually did to prevent further scratches was bend the little last bit of the license palte under and flattened it behind the plate. From the front it looks like a normal plate. If I repair it myself, I want them to pay for everything, even if it is five bucks, and they should do the work. I payed for the car and their design scratched it, they should fix it and eat the cost. Good idea though Magz, I will have to try that on my other car and maybe the Lancer if they don't budge and pay to fix it.
Old Jun 27, 2003 | 12:19 PM
magz's Avatar
Yeah... I didn't even notice that the license plate was scratching the front lip until it was too late and a friend told me. The dealer installed my license plate and did a half *** job.
I just fixed it, it only took me 25 to 35 minutes to screw the heck out of it and fix the paint. It looks worse than it is because the license plate scuffs the lip because it is metal. Once you clean it they aren't very big/deep scratches. Then I just used the scratch remover from Meguir's and it was good to go! Good Luck!
magz
Old Jun 27, 2003 | 12:23 PM
zlancer's Avatar
i don't know if tightening the plate that much is a good idea. your going to wind up over tightening and stripping the threads. just be carefull
Old Jun 27, 2003 | 12:24 PM
magz's Avatar
VALancerOz,
I'm from VA BCH also... I'm moving to Orlando right now.
I live by Indian River and Providence...
magz
Old Jun 27, 2003 | 12:27 PM
honestly your best bets to solve this problem since we are all tuners anyways are threefold.
1) Mount your license plate below the openning (see Boeturbos Lancer and fill and paint the old holes
2) Mount your license plate off to the side (since we are all buying intercoolers [RIGHT?] you'll have to move it anyways to allow airflow and biatches to get to the intercooler.
3) Buy a new bumper and mount the license plate with the least amount of problems
4) Take off all your plates and drive it like you stole it. When the cops lay the spike strip, pop holes in your ES-100's, break your arm while handcuffing you and take you off to jail, no license plates will be the least of your worries!!!!
Old Jun 27, 2003 | 12:28 PM
magz's Avatar
zlancer,
If you go out and remove the rubber boots you will see that is how you use it. The screws will screw completely through the boot. This is how you use the boot and screws. I had another car with these same boots. It only squeezes the boot against the bumper. The threads can't be over tightened or stripped because they go completely out of the boot.
magz
