Need your help
Old Dec 26, 2007 | 03:31 PM
Show Off's Avatar
Need your help
I just put my lowering springs on my car (Tein) and my tires are rubbing the inner fender. Since I have the walker body kit the inner fender don't even fit , so what i need is to know how to make a new inner fender for my car so it will not rub and fit.
Old Dec 26, 2007 | 03:58 PM
atilla's Avatar
roll them!
get a baseball bat (one of the little ones), jam it in there and roll the car a little bit.
oh, and there's something you're supposed to do so all the paint doesn't come off... my friend and i didn't care since his lancer is track-only now.
Old Dec 26, 2007 | 04:09 PM
ambystom01's Avatar
You use a heat gun to stop the paint from chipping. What size wheels and tires are you running? Like atilla said, worst come to worst you can get them rolled at a speed shop. I have no idea what having a body kit has to do with the fenders.
Old Dec 26, 2007 | 04:47 PM
Show Off's Avatar
INNER FENDER is rubbing and i just want to know if anyone knows how to make new inner fender wells or re-mold them so my tire will not rub
Old Dec 26, 2007 | 05:29 PM
ambystom01's Avatar
You could remove the fender liners and see if that helps. If it's the actual metal fender that is rubbing, you'll have to do some fabrication to fix it. What tires are you running and what offset?
Old Dec 26, 2007 | 06:51 PM
Show Off's Avatar
I got 205/45/17, if i remove the inner fender wells my engine will get dirt as hell
Old Dec 26, 2007 | 07:10 PM
ambystom01's Avatar
Well here's info on offset if it helps. https://www.evolutionm.net/forums/sh...d.php?t=247411
No idea why the tires are rubbing since according to the tire calculator they should work fine. I'm guessing the offset is wrong.
Old Dec 28, 2007 | 10:48 AM
Show Off's Avatar
problem solved, went and got a blow torch and reshaped the inner fender. thanks guys for you help
