Body kit-Paint
Old Aug 27, 2003 | 07:07 PM
OZBOTS's Avatar
Question Body kit-Paint
When you get a body kit do they paint it first or do you put it on then have it painted?
Old Aug 27, 2003 | 07:13 PM
cincyracer2002's Avatar
you paint it
Old Aug 27, 2003 | 07:21 PM
pumpdog720's Avatar
You can have it painted by itself I guess. Then just put it on when it's ready. I guess it's up to the body shop who wants to do it.
Old Aug 27, 2003 | 08:05 PM
rbbcustom's Avatar
It depends. if you want a perfect match they will paint the edges and then put it on and then paint and blend. If you want just close they can paint it and then put it on.
Old Aug 28, 2003 | 02:12 PM
JDavies's Avatar
You fit it first to make sure that there is no area that might need to be filled in then you spray the edeges. then fit it on the car and attach then after you have filled/ remolded depemding on the kit you paint
Old Aug 28, 2003 | 02:31 PM
deuxforever13's Avatar
they can paint it first and then install, or install and then paint.
ur choice man, unless the body shop sez otherwise.
i got mine painted then installed, cuz i wanted the insides of the creases be painted too, thats just me.
but if u want it to be really accurate blend, install it first and then paint.
dont get me wrong tho, even tho i installed mine after painting, its really great job they've done.
if u go to a reliable and respected shop, u just give 'em the code and they'll do it good.
Old Aug 28, 2003 | 02:47 PM
zlancer's Avatar
a lot of good shops i've been to fit the kit first...take it off then paint it. then they put it in like a huge tanning bed to fade the paint to match your car (if it needs to be)...since your paint fades by the UV rays from the sun then they put it on the car. it would be stupid to paint the kit when it is on the car because the you would have to spend a lot of time covering the car to protect it from overspray and whatnot.
