need help with tranny prob& tail light prob
Old Oct 17, 2008 | 12:11 AM
808tyson's Avatar
i have a 03 lancer es automatic trans. ok when i shift from park to drive it goes in to gear but it goes in to gear hard like its pounding it into gear or when i shift from drive to revers it pounds in to that gear as well and when i was driving it around it drives fine but it only seems like it has one gear // and now my tail lights don't work well when i step on the break it work but running tail lights don't work so i cant drive at night .could it be a senser or some thing
Old Oct 17, 2008 | 01:00 AM
Lumpy's Avatar
Has the tranny fluid ever been changed? You may also want to check the condition of your engine mounts. There's one in easy sight under the middle of the engine, above the support in the center. The other one is towards the back of the engine, and harder to get at. I'm no mechanic, but I sold auto parts for a loooong time. The pounding into gear at first had me thinking bad motor mounts, but seeming like it has only one gear sounds like the transmission might be bad, which was why I asked about the fluid being changed. Not changing that can ruin the transmission.
As for the taillights, did they work for you before, or did you just get this car? If you just got the car, someone might have put in the wrong taillight bulbs to save a buck, possibly causing them not to work properly. This is the easiest scenario I can think of, and the easiest to check. Other than that, has the car been rear ended? Those are the main things popping up in my mind. Good luck.
Old Oct 17, 2008 | 01:35 AM
808tyson's Avatar
trans working fine now it was because i took the negative battery term off and ecu reset so car was running to my racing specs and not to my normal driving so i took off the negative bat cable again and now it runs like a champ but for the tail lights i had the car for some time and just got some hyper white bulbs for it so it would be brighter and better to see when im stoping but they are not working at night like when im driving or parked if i step on the brake it comes on but no running tail so people can see that im on the road from behind
Old Oct 17, 2008 | 01:39 AM
808tyson's Avatar
trans is working fine now just had to reset the ECU because i took off the negative battery cable and it had reset itself and i went racing around so it was thinking thats how i drive so i had to reset it.but still need help with tail light prob
Old Oct 17, 2008 | 12:48 PM
Lumpy's Avatar
Could still be the wrong bulbs. Stock are probably dual filament, what you have sounds like single.
Old Oct 18, 2008 | 09:18 PM
808tyson's Avatar
yea it was the bulbs the guy at the shop gave me the wrong ones they were single filament not two like i need it but i returned them and got my new right bulbs so thanks for the help
