Stock Exterior/Interior Bulb Replacement
Old Nov 24, 2009 | 11:38 AM
  #181
sicx13's Avatar
in my lancer i had replaced all the bulbs with leds from superbrightleds.com. they DO NOT light up evenly and you will be dissapointed
Old Feb 4, 2010 | 06:40 AM
  #182
Jogenmaru's Avatar
This is for when my door opens.
Compliments of http://store.ijdmtoy.com/
Last edited by Jogenmaru; Feb 4, 2010 at 06:46 AM. Reason: add link to lights, sharing the knowledge
Old Feb 4, 2010 | 06:41 AM
  #183
Jogenmaru's Avatar
And this is if I need to search for something at night.
Old Jun 21, 2011 | 04:17 PM
  #184
Zydas's Avatar
Originally Posted by Iamkar33m
Stickied!
wicked
Old Aug 19, 2011 | 07:06 AM
  #185
LIVEEVIL's Avatar
how do you change the bulb in the trunk? It was dark when the bulb went out so I couldn't get a good look at it. Any suggestions?
Old Dec 24, 2011 | 01:37 PM
  #186
slOZrally1's Avatar
does anyone have any pics of red bulbs in their cluster gauges? because i ordered t1.5 red led bulbs, they were a tad too big and when i turned my interior lights on, the gauges were dark except for a small circle where the bulb is... -_-
Old Feb 5, 2012 | 09:39 AM
  #187
JesseOZ's Avatar
I have a 2003 Lancer OZ. Has anyone noticed their stock red dash cluster to be dimmer than most cars? I just bought the car not long ago and have trouble seeing the odometer at night amongst the other gauges! The dimmer switch is at max, still doesn't seem bright...
Also, one back light for the A/C, vent controls in the middle consol is sometimes on then goes out intermittently. I took the paneling off, tapped the light panel and the light turns on then hit it again and the light goes out....could this be a problem with the bulb itself? Or a connection problem? Also wondering if anyone knows where I could get one of these bulbs? Which I believe to be a #74
Old Feb 13, 2012 | 04:00 PM
  #188
JesseOZ's Avatar
Just for a heads up; the Climate control back lighting bulbs are not #74, although they do fit. 74's are slightly bigger than what was in there. To get the 74's in you have take off the twist attachment in the back, remove the old bulb, twist the connector back on and then put the 74 bulb in from the front. The 74's separate the twist connector when inserted making it too wide to twist back into place.
This was for an 03' Oz Rally
Old Mar 19, 2012 | 06:39 PM
  #189
betelgeuxe14's Avatar
Hazard button switch
Hi can anybody confirm if the hazard button for lancer OZ lights up?
Old Mar 28, 2012 | 02:38 PM
  #190
23tb3voMRs3's Avatar
Originally Posted by drummerjun
headlight bulbs - 9007
front/rear turn signals - 1156
parking light - 168/194na
side turn signal - 168/194na
rear license plate - 194na
back-up light - 921
interior ac control, cigarette lighter, ashtray, lights - 74
trunk light - 3022
dome light - 3175
brake lights - 7443
stock cdplayer = dim control - ? *!not! 74*
am i missing out anything?
Could somebody add the wattage/voltage too...?
are those specs also for a evo 9? And has anyone find out the wattage/voltage too?
Old Mar 31, 2012 | 08:28 AM
  #191
JesseOZ's Avatar
No it doesn't light up for my 2003, however not sure about newer models.
Old Jun 8, 2014 | 04:26 AM
  #192
fandadar's Avatar
I'm stuck at work and not able to get to my manual, could someone please tell me what the replacement bulbs for low beam, high beam and fog lighrs are for a 2010 gsr
Old Aug 14, 2014 | 02:22 AM
  #193
averybadcat's Avatar
Very pleased with the gauge cluster, HVAC, and dome light I purchased from Super Bright LEDs. Huge improvement. Very pleased.
Lights I bought:
NEOx-xHP:NEOx LED Bulb - High Power Instrument Panel LED - NEO5-RHP:5mm NEO5-xHP Red (x3)
NEOx-x:NEOx LED Bulb - Instrument Panel LED - NEO5-R:5mm NEO5-x Red (x2)
3022-x4: DE3175 LED Bulb - 4 LED Festoon - 3022-CW4:Cool White (x1)
After installation, as well as one of the lights in the HVAC, my engine service light and parking brake light no long function.
Does anyone have experience with this? Are there wiring diagrams out there?
Last edited by averybadcat; Aug 14, 2014 at 02:25 AM. Reason: LED Festoon part number "...:de3175" was replaced with a :D emoticon by accident
Old Sep 3, 2014 | 09:15 AM
  #194
spacejamzx1's Avatar
2014 lancer
Do these sizes apply to the 2014 lancer es as well?
Old Sep 22, 2014 | 01:03 PM
  #195
CNOEVO22's Avatar
a little late for the reply but the bulbs most likely burnt out when you were taking it apart the cluster. happebs alot. just replace the bulbs
